Question about Philips Magnavox 51MP392H Rear Projection Television
Hooking up my t v to my computer
I need to know the right kind of cable to go from my mag, 51" tv to my new toshiba computer to run high def d v ds' ?I
  • 8,596 Answers
Even though, logically, you could hook up DVI to DVI, it just won't work with this television. Sorry.
Posted on Mar 20, 2008
How do you hook a sony blu-ray dvd player to a Toshiba 51H83 51-inch HDTV
Step 1:
Hi there you need an adaptor follow this link
Step 2:
Dec 29, 2012 | Sony BDP-S590 3D Blu-ray Disc Player with...
I had a new high def tv installed.the cable company hooked up there box .now i cant record anything on the vhs.
was the VHS recording before the new high definition TV was installed? Or are you trying to say that the cable company has tempered with the settings of the VHS?
Probably, the cable company, has removed the cable for the player. Check the back of the player and let me know if the cable between the player and the TV are intact.
The above needs to be verified for accurate solution.
I look forward to your reply.
Bye for now.
Jan 20, 2011 | Sanyo DVW-5000 DVD Player/VCR
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
I have my polaroid hooked up with an hdmi cable
Thats because your TV is not high definition and cannot process the high def signal. serial hook up does not give a highh def signal.
Nov 09, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Xbox 360 sound but no picture can any one help
If you've just bought your xbox 360, then you probably haven't got a HDMI cable.
Which I think you could need.
Aug 18, 2009 | Microsoft Xbox 360 Console
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
Toshiba 43H70 - making it HD
you cant make it high Def. The converter only allows and analog tv to recieve digital signals, But it wont make it a HDTV
Apr 03, 2008 | Toshiba 43H70 43" Rear Projection...
P3 not playing high def dvd
make sure your tv input is on the right selection
Dec 10, 2007 | Sony PlayStation® 3 (60 GB) Console
Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Nov 04, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Philips Magnavox 51MP392H Rear Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
