Question about Maytag PDB3600A Built-in Dishwasher
Rinse aid not dispensing
The rinse aid will not dispense... is this something i can rectify? I filled it, washes later it is still full. Months later it is still full. Help?
4 Suggested Answers
  • 195 Answers
SOURCE: rinse agent not dispensing
Hi I will try and explain how it works , if you look at the cover for the rinse it has small slots on it as the water splashes around inside it and this makes the agent come out if this cover is blocked or dirty it won't let any come out .. I always tell ever one to use less soap then the box says to use and always use a premium type soap , not the wal-mart brand , think about t if you have to clean your dishes after they are washed then why have a dishwasher ? I always say that is what teenagers are for
Posted on Dec 12, 2011
SOURCE: Rinse Aid does not dispense
http://www.partselect.com/ModelFrames.aspx?ModelID=149370&ModelNum=PDB2600AWX&mfgModelNum=&ManufactureID=1&Selected=54869&Position=1&mfg=Maytag&Type=&Mark=3
From diagram RINSE AID & SOAP DISPENSER, replace 138912t.jpg PS138912
Wax Motor for Detergent Cup Actuation.
Posted on Apr 27, 2008
SOURCE: Kitchenaid KUDS02 Rinse Aid dispenser does not work
I don 't know how to fix the dispenser; however, there is a jet dry product that is sold in stores that is in solid form, you just clip it to the upper rack. I have seen it in Wal-Mart in the detergent aisle.
Posted on Apr 18, 2009
The rinse aid light on my Miele dishwasher won't turn off even though the dispenser is full
There are two ways of dealing with this:
1. Leave it alone, checking the rinse aid every month.
2. Find the fault.
The fault is likely with either the level detector, which will probably mean a replacement rinse aid dispenser or with the cabling. Try disconnecting the detector cables and seeing if the light turns off (make sure it's the detector cables, not the doser). If the light turns off, the likelihood is that the detector has failed. If not, then the fault will lie elsewhere, possibly with the logic board.
Jan 28, 2015 | Miele Dishwashers
The last few times I filled the rinse dispenser and ran the dishwasher I notice the arrow showing the rinse aid is almost empty. Impossible. What is going on with this?
THE ANSWER IS YES. FROM YOUR DESCRIPTION IT SOUNDS LIKE THE DISPENSER PUMP OR RESERVOIR IS LEAKING. YOU NEED TO REPLACE THE WHOLE SOAP DISPENSER. ALTHOUGH DISH WASHERS NEED THE HELP OF RINSE AID IT IS ONLY DISPENSED A DROP OR TWO AT A TIME DURING THE FINAL RINSE CYCLE PART OF THE WASH. HOPE THIS HELPS AND THANK YOU FOR READING THIS.
Oct 07, 2014 | KitchenAid Dishwashers
Smeg di612ca9
Most likely you need new dispenser and you could buy it on line or you could get it from your local service centre as they might be able to order it for you
Dec 09, 2013 | Dishwashers
Hi.I have rinse aid light on since yesterday and i cant figure out wath is it about
It means the dispenser for rinse aid is empty . Fill the rinse aid dispenser with rinse aid
Feb 24, 2011 | Washing Machines
How much rinse aid do I put in my dishwasher and how do I use the arrow within the rinse aid dispenser in the machine.
The dispenser will take about 6 oz of rinse aid if completely empty. It will only need filled every couple months depending on how often you do dishes.
If you are getting poor drying performance or spotting use a rinse aid that is called 'Turbo Dry'.
The arrow is how much rinse will dispense each load. Start out near the center, if you see spotting or turn it up slightly and try another load.
Aug 22, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
HOW TO PUT RINSE AID INTO THE DISPENSER CORRECTLY???
if you're referring to rinse aid for a dishwasher, just unscrew the dispenser lid, and fill the dispenser with rinse aid, then screw top back on.
Mar 22, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Rinse aid not being released
Most likely the actuator for the rinse aid dispenser is not functioning.
Jan 13, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Rinse dispenser not dispensing the rinsing agent.
not a very common issue,the unit only spits a few drops of rinse aid every use, so assuming you filled the compartment , that will hold enough rinsing aid for 35-40 washes before needing to be refilled. is it possible taht you havnet waited long enough for it to use this much detergent?
Nov 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Sep 28, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Feb 20, 2007 | Maytag 24 in. MDB4100 Built-in Dishwasher
Maytag PDB3600A Built-in Dishwasher Logo
137 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
