Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby vaccum ultimate G
The belt just broke on my vaccum and I'm trying to put on a new one. Couldn't figure it out and can't find my manual! Can you help?
  • scwillow Jan 14, 2008
    Thanks domvac! It was that final step that was throwing me. The belt went into place with no problem. I am happy to report that I was able to finish my sweeping and the kirby is now back in the closet.
  • Anonymous Feb 24, 2008
    how do you put a belt on kirby vaccum
  • 126 Answers
Lift the light bulb housing up and you will find a latch that will rotate to release the front agitator housing and remove it from the machine. On the bottom of that housing, there are two latches that secure the bottom plate that covers the roller. Remove the plate and the roller will come out. Be sure to notice that the roller has a magnet at one end that lines up with the indicator that shows you when the roller is turning - it's the little green light that glows while you are vacuuming. The roller needs to go back in the same way it came out. O.K. Take your new belt and position it around the middle of the roller and drop the roller back into place and replace the bottom plate. On the front of the housing, there is a big square "knob" and you can rotate that piece. If you look inside the hole on the other side of the agitator housing, you will see that there is an arm that moves with the square knob. The end of this arm will catch the belt and with a little effort, the knob will rotate and lift the belt into position for replacing the housing back on to the machine. once you have the housing back on the machine and secure, you rotate the square knob back around and the belt will sit down on the drive shaft. If you look at the top of the agitator housing just above where the knob is, you will see a red and a green arrow which indicate which way the knob turns to do the "remove" belt or "replace" belt. I hope this helps. Once you do it properly, it actually is quite easy.
Posted on Jan 13, 2008
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Thanks for watching!
Chris J.
Nov 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Belt broke on shampooer
there are screws on the ends. I got it fixed.
Apr 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series also works for the new model.
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Recently received a kirby from mother in law and don't how to change the belts
Dec 15, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
76 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
