Question about Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner
Won't read any cd
When I boot up the drive is in my folders under explore, When I double click on it in explore with a blank disk in it, I am told it is not assesible, incorrect funtion. When I double click on it with no disc it tells me there is no disk in the drive. In device manager it tells me it is working properly.
I am running windows XP professional, I can hear and see the drive running and can find nothing wrong. I took the drive and put it in my other laptop (I have two the same) and it works fine in that one. I have checked cables till I am blue in the face.
It appears to be something in the system software not the hardware but I can find nothing.
Can anyone help
  • inglis Jan 13, 2008
    I have checked this and under Primary there is Device 0 and Device 1 both are on DMA if available
    Also checked this on the secondary there is Device 0 and Device 1 both are on DMA if available
    Master:
  • 788 Answers
Go to device manager and check the properties on both controllers under IDE ATA/ATAPI controllers. They should be set to DMA under the advanced options. If set to PIO change it.
Posted on Jan 12, 2008
  • Dean Joly
    Dean Joly Jan 13, 2008
    Have you tried an audio CD that you know plays well in a stereo?
6ya staff
SOURCE:
I have some photo cd's and don't know how to download them to a file on my PC. Can you help me?
insert the CD to your dvd-Rom then open windows explorer. Go to the DVD-RW drive to your CD folder, then crop or extract every *.jpg extension to your drive C. You can customize or create a folder to which you are going to save the photos from your CD.
Mar 06, 2011 | Computers & Internet
Hi everyone, I would just like to know, does anyone know how I can obtain or create an emergency boot up disk for windows xp home edition? Many thanks. Andrew
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
Jan 15, 2010 | Computers & Internet
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
Nov 15, 2009 | E-Machines eMachines Desktop PC
My cd reader in my hp pavilion dv6000 is not reading properly. when i put in a cd i see the little green light blinking and i hear the cd spinning but thats all it does.
sorry to tell you but your Cd drive is bad it is fairly cheap and easy to install usually two screws and give the drive a little yank and it should pop out you can purchase the CD drive online try ebay good luck but make sure first im not sure if maybe you think that something is supposed to happen every time you insert a cd it does not insert your CD go to my computer and try to access the drive if you can browse the files then your drive is ok sounds like you need to enable Autoplay a feture that enables something to happen when you insert your cd but you probaly know all that ...
Nov 03, 2009 | HP Pavilion dv6000z Notebook
Non-recognition of disks in cd drive
Your CD-drive is failing to read the blank disk.
Thus, it cannot confirm that the disk is blank.
Replace the CD-writer -- it's "dead".
Sep 19, 2009 | Sony (CDU5212) Internal 52x CD-ROM Drive
I am trying to burn a disk with my Dell 4300 Computer. When I in
1) Insert a Blank CD-R into your CD Drive and push the button to close the door.
2) Wait a moment for the What do you want Windows to do? box. If
this box does not appear, you can open the Windows Explorer by
double-clicking the My Documents icon or the My Computer icon
on your Desktop.
3) When asked What do you want Windows to do?, click Open
writable CD folder using Windows Explorer.
4) Once the Windows Explorer opens, click on the link on the left that
says My Documents to get to your My Documents folder.
5) To copy everything in the My Documents folder to CD, click Edit
and then click Select All. All the folders and documents on the
right will be selected.
a) Note: If you only want to copy certain files/folders to CD, hold the Ctrl
key on your keyboard to select only the files / folders that you want to copy.
6) Once your files are selected, click Copy the selected items on the
task pane on the left side of the window. (If you do not see these
words on the left, click the Folders button once.)
7) When the Copy Items box appears, select the CD Drive (D:) and
click Copy.
8) Once the files are finished copying, you will see a balloon in the
bottom right corner of your screen saying that You have files
waiting to be written to the CD.
9) If you are only copying you’re My Documents folder to CD, you
can click that yellow balloon to complete the CD burning process.
Note: If you do not see that balloon, wait a few more moments. If you still
do not see it, click on the My Computer link on the task pane on the left,
then double-click the D: drive. Then proceed with the next step.
10) Clicking the balloon will bring you to the D: drive and you will see
the files you have copied under the Files Ready to Be Written to the CD section.
11) On the left, click Write these files to CD.
12) You will be asked to type a CD name. This simply gives the CD a name and is optional (16-
character limit).
13) Click Next.
14) When the CD Writing Wizard is complete, your CD will be ejected and you will see a box telling
you that you have successfully written the files to the CD. Click Finish.
15) To ensure that the files have been successfully written to the CD, insert the CD again and wait a
moment. The CD and its contents should appear on your screen after a few seconds.
You can continue to copy files to this CD until the CD is full. When the CD is full, you will be told so by
Windows. CD’s cannot be erased. Once a file is copied to a CD, it is permanently there.
The files that you have copied to CD are Read-Only. This means that you cannot make changes to a
file on the CD and save those changes directly back to the CD. If you want to change a file on the CD,
you must open the file, save it to your PC’s hard drive (My Documents or Desktop folders are
recommended), then follow the steps above to copy the file back to the CD, clicking Yes when asked if
you want to replace the file on the CD with the new one.
Jan 17, 2009 | Dell Dimension 4300 PC Desktop
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
How to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
Sep 28, 2007 | Microsoft Windows XP Professional With...
Open Questions:
See all Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner Questions
Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
