Machine not working
The word test has come on screen and no water is going to machine.
    President:
  • 1,294 Answers
Try pressing the "on" and "start" button together for over 5 seconds.............. the demo code should come off.
You will rate me pl. if helped....................
Posted on Jan 13, 2008
I have a Gaggia "coffee" and no water goes through
Remove the 2 allen wrench screws under the screw and screen, this will drop the diffuser, careful do not loose spring and plastic ball that is in there. Then run machine without parts in place to check if water goes through. If yes replace parts minus screen and screw and test, it taht works insert screen and screw and test.
Sep 21, 2011 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Error code 7 - EcoSmart Washer - Fisher and Paykel
Hi there, what is the exact model of you washer?
Mar 22, 2008 | Washing Machines
Why is my machine flashing a tap sign and stopping?
Hi and welcome to FixYa, I am Kelly.
Turn off the water at the wall connection and remove the water hoses from the inlet water valve. Remove the inlet screens and wash them under slowly running water by rubbing your fingers over them. Reinstall the inlet screens and re-connect the water hoses to the machine. Remove the hoses at the wall connection and make sure the installer has not installed inlet screens on the hoses. If there are inlet screens on the hoses also clean the inlet screens. Then reconnect the hoses.. turn on the water and test for leaks then test the machine.
This should get you going unless you have relly low water pressure in the home.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Hotpoint WMA74 Front Load Washer
What is a LF code on a Kenmore Oasis washer?
LF( long fill) shut water of clean water inlet screens//Turn water back on check for leaks test machine. screens are also in water inlet valve were hoses go onto machine///note both hot and cold must be turned on to that machine to work right Good luck if i helped please vote...need more help just ask..
Feb 03, 2011 | Kenmore Washing Machines
I start my washer and there is a buzzing noise that comes on when the water is suppose to be going into the machine
Is water turned on ? turn water of// clean screens in water inlet lines also screens in the water valves itself clean those put back in turn water on check for leaks and test machine ..If I helped you please vote/// If you need more help just ask.....good luck
Feb 02, 2011 | Kenmore HE2 Plus Front Load Washer
Washer just hums when time for the water
Check the water water supply at the water inlet valve. Remove the supply hoses and check that the small screens in the inlet valve are not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 14, 2009 | Washing Machines
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not turn on
Dear customer
plaese perform the following checks
There are two circumstances to get this problems ,and i had showed the two different probabilities occur this problem so go through the following
(1)Washer does not work and makes no noise :
(2)Washer does not work but it does make noise:
Please rate this,Thank u
Dec 17, 2008 | Washing Machines
Odd messages appearing on lcd screen and not collecting water
What make and model is your washer?
Cannot help without further details
Nov 19, 2008 | Hotpoint Washing Machines
Kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
please rate this solution if it meets ur need, else choose fixya.Thank you..
Nov 11, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
