Question about HP Photosmart R847 Digital Camera
I live in london england, where can i go to fix this camera.the battrie is not staying in the slot,neither the sd card. and the covering is not staying shut.I want to secure it but don't know where to go and get it repaired, as I baught the camera in America.Hp Photosmart R847 Digital camera. please help
    New Friend:
  • 20 Answers
You are so lucky that you live in London. For me it is a dream city and I really want to visit London. There are several classy lists of places that must be visited in London. And when I go there, I will definitely do everything as it is written there. Londons Ten Most Popular Attractions
Posted on May 30, 2018
    Brigadier General:
  • 4,090 Answers
CAMERA CITY
LONDON, WC1A 2HN LONDON, 16, LITTLE RUSSELL STREETGreat Britain
fast camera repairs, repair cameras, camera bought & sold digital & camcorder repaired part exchange welcome
LONDON CAMERA REPAIR CENTRE
LONDON, W10 5PS LONDON, 72 GOLBORNE ROADGreat Britain
photographic equipment repairs
CAMERA CARE
LONDON, W1T 1UG LONDON, 20 HANWAY STREETGreat Britain
Please rate my help++++Thanks for using FIXYA
Posted on Nov 23, 2009
SOURCE:
Hi all. how do I access the Sd card slot spring inside my gopro hero 4 silver,
hi,
oh, the remedy is to open the cam then desolder the memory slot's casing very carefully, fix the spring in proper position, then solder the cover.
Feb 11, 2016 | GoPro HERO4 SILVER
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Nikon D40 - The memory card will not stay in. If I put it in and close the door, it still must not "click in" far enough because the camera won't recognize it. The only way it works is if you...
hi Jfurbees.
this is all i could think off just to help you out in till you can get it fixed.
I don't have a permanent fix, but one thing that works is folding up a small piece of paper and holding it over the memory card while closing the cover so that the cover pushes on the paper which holds the memory card in place automatically when the cover is closed. You just have to experiment to get the folded paper the right size and thickness. Again, its not a fix, but it has worked for me.
I shone a really bright light into the SD slot and sure enough, behind the gold springs at the bottom of the card slot, was a tiny black sliver of plastic that moved slightly when I tipped the camera. About 3mm long.
I removed the camera battery. Then I got a big long sewing needle, and with some very gentle manouvering, so as not to scratch anything inside the camera's SD slot, it fell out just when I was about to give up.
After I'd got the plastic sliver out, I trimmed the splintered edge of the SD card and put it back in
this is not to say it will work for you but give it a try but this will be at your own risk.
Dec 01, 2017 | Nikon D40 Digital Camera with G-II 18-55mm...
SD card will not stay in
Take the camera for professional repair. It's probably a manufacture fault, or a transport damage.
Apr 07, 2010 | Pentax Optio S50 Digital Camera
HAVE SDHC CARD 4 GB IT WILL NOT FORMAT
The Z740 takes SD cards. Cards bigger than 2GB are SDHC cards, as you've mentioned. While SDHC cards will physically fit into an SD slot, they are not compatible. SDHC devices will accept SD cards, but not the other way around. it's a hardware issue; you can't fix it with a firmware update. You will have to stay with cards 2GB or smaller for this camera.
Jan 30, 2010 | Kodak EasyShare Z740 Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
Do not know why my camera is saying that my card needs to be formated' I brought it into London Drugs camera department and they could not help me they say that I need to find the manual; a manual that I...
This camera only supports an SD card of 1GB maximum. I tried a 2GB SD card and the camera reported the error you describe, that the card needs to be formatted (and it wouldn't format in the camera, either). I purchased a 1GB Duracell SD card P/N DU-SD-1024-C at Wal-Mart, and it was actually a 2GB card (tested in my desktop PC's SD slot and it was fine). Nice deal, but this camera can't use it. I bought a 3-pack of Kodak 1GB SD cards at Wal-Mart and they worked great in this camera.
Dec 23, 2008 | VuPoint DC-M306AT-VP Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
SD card will not stay in camera
Try to use another SD card in your camera. If the phenomena is still exist, the problem is with your camera (in most of the cases it is a broken plastic part of card's "house").
Nov 14, 2006 | Pentax Optio S50 Digital Camera
HP Photosmart R847 Digital Camera Logo
395 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
