FixYa.com
Tags:
ECS 945GZT-M  Motherboard
ECS 945GCT-M/1333 System Board (by 4 users)
posted by JimboRawls on Jan 12, 2008
Continue to get a "pcy.sys" blue screen when attempting to install windows XP Pro. I am Microsoft certified and have seen this issue before, but using the onboard VGA with a standard analog LCD shouldn'tg be an issue.
Has anyone seen this and what BIOS setting addresses this? ECS website doesn't do much!
thx, Jim
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Apr 24, 2008
drivers
Comment by bigubig, posted on Feb 06, 2008
BSOD on win xp install ( ECS945gct-m/1333)
used pcie graphics card same problem . flashed
bios with latest version from ecs website still bsod
cpu e2160
Comment by jim1937, posted on Feb 01, 2008
ecs 945gct-m/1333 MB with core 2 duo cpu
blue screen (pci.sys) when trying to install xp or boot from a hd with xp (sp2) installed. I can install debian linux and ms vista. I even tried to install xp with a pci video card installed, but same results.
The bios is correctly set.
Any suggestions appreciated.
Clarification Request
by tom19511, posted on Jan 13, 2008
pcy.sys?
Does it give any other errors?
Best Solution
posted on Jan 31, 2008
FixYa! (100)
Rod Earl
Rank:Apprentice Apprentice
Rating: 96%, 10 votes
If service pack 2 is not installed that will cause the problem. I learned this from a Fry's return / Mother board test person.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 10, 2008
FixYa! (100)
paslug
Rating: 95%, 3 votes
Rod Earl solution worked for me. The first SR2 cd that I tried was too old, & still didn't work. I slipstreamed SR2 that I downloaded from ms into my original xp cd, then it installed perfectly without a problem.
I found the slipstream instructions here
http://www.theeldergeek.com/slipstreamed_xpsp2_cd.htm
Solution #3
Helpful (85)
map9966
Rank:Guru Guru
Rating: 88%, 1056 votes
I can see you getting an error with pci.sys but not with pcy.sys.
Did a full system scan in a working WinXP Pro & found not such animal within the system or regestry. After looking through microsoft I did come across pci.sys and what may creat such an error. I would point to your onboard VGA. If intergrated into the board as I suspect. It is a pci device. During install windows found something wrong with it hence your error & blue screen. Suggest using your PCIE card & set bios to same disabling the VGA. Your install should no longer fail.
Good luck & please vote!
Rating Locked! (?) JimboRawls has rated this solution as Helpful
Solution #4
posted on Feb 03, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Here I am with a similar problem - There's no obvious method to select the onboard VGA adapter. Contracted tech support and they said to select the "PCI Exp_VGA" setting in the Bios instead of the "PCI Card" (default). However, there is no entry for "PCI EXP VGA", only one for "PCI Express Card" and the default "PCI Card". This was not very intuitive and I assumed that tech support knew what they were talking about. I also have a problem with the entries because the screen says "Select which graphics controller to use as the primary boot device". Selecting either one picks up the onboard VGA adapter, which doesn't make too much sense, but again it might be semantics. Getting about ready to take the board and CPU back to Frys and get another board that may or may not work. What I'm seeing when I try to load WinMe or XP, it says Windows didn't get initialized all the way and puts me in Safe mode. Clicking on the Safe Mode just goes out and returns to the Safe Mode again. Sure would've been nice for them to put a BIOS entry that would allow one to select the onboard or external PCIEX16 card. I would try to use a PCIEX16 card, but paying $50 for a mobo and then putting in a $250 PCIEX16 card doesn't make sense.
Anyone else has seen this problem?
Can you Help with these Motherboards problems?
Motherboards
No operation system found..
I have brand new HDD and i dont... Answer This...
Motherboards
which mother board to go with
i'm buying 2 visiontek radeon... Answer This...
Motherboards
PC Chips M955G Motherboard...
I am looking for a diagram to... Answer This...
Motherboards
Drivers Network Card
Super p4 sce Answer This...
Motherboards
laptop system board
the system board, lcd, and key... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
