Question about HP PSC 1210 All-In-One InkJet Printer
Paper feed error
I'm getting a strange error when attempting to even copy a document with this printer. It begins to feed a sheet through, then stops, reporting an 'E' on the little 'Copies' box. I then hit Cancel and it finishes feeding the paper through.
My first thought was a jam, but as it continues to feed the paper through, I don't think that is the case. Any help would be appreciated.
    President:
  • 4,402 Answers
Cleaning paper rollers
  1. Turn off the unit, then unplug the power cord.
  2. Remove the rear access door. See the picture above.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 7: Paper rollers Paper feed error - c00109674.jpg
  4. Allow the rollers to dry completely, then replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area, then snap the door shut.
  5. Plug the unit back in and turn it on.
Posted on Jan 15, 2008
6ya staff
SOURCE:
Scanner not feeding on lexmark x7170. paper feeds halfway in them reports error/clear paper jam in scanner document feeder.
I have the same all-in-one printer and have just recently, the unit is a few years old, started having the same problem. I found that that if I make double sure the pages are evenly stacked and very carefully placed in the feeder tray, the problem is less common. It doesn't work everytime but ar least I get my faxes through on the first attempt 75% of the time.
Nov 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
I've got an HP R40 multifunction printer. Yes, it is old, but it don't know of another printer out there that will do what it does. I'm having a problem when I try to copy something, it will scan the...
I had the same problem and HP claimed it was the roller on the feed unit. I do think they are programed to feed a little different for scaned documents than copied docs. HP gave me a new printer worth more rather than even try to fix it. Here is a tip. Take the insurance on the extended protection especially if you have a 4 unit function (fax, scanner, copier and printer) chances are 1 function will break before the end of your extended protection. You always get a new unit, rather than them fixing it. It's really worth the 50 bucks if you buy a high end unit.
Aug 10, 2010 | HP OfficeJet r40 InkJet Printer
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printer paper jam
Do a printer check by copying on standalone. means placing a document inside the scanner. Load 10 sheets of regular paper into the feeder then press the start button to begin copying. Try 2 copies. If it gives you the same error, then there is already an issue with the gear inside the printer.
If your unit is not under warranty anymore, log on to support.epson.com. Click on help me find a service center to the right of the page. You will have to put in your zip code to find an epson certified servicer near to your area.
If your unit is not a year old yet, please call epson technical support.
If it copied successfully, it could be just the paper settings, or the type of paper that you are using is not supported or you might have to uninstall and re-install drivers.
May 06, 2009 | Epson Stylus RX580 InkJet Photo Printer
When using the adf get error message
Advice is terribly difficult without a model number of your machine
Mar 06, 2009 | Canon Office Equipment & Supplies
Printing a report
IS IT THROUGH EXCEL THAT YOU WANT TO TAKE THE PRINTOUT FROM? YES - OPEN A FRESH EXCEL SHEET. COPY AND PASTE EVERYTHING INTO THE NEW SHEET. TRY TAKING A PRINTOUT. YES - GOOD. NO - UNINSTALL AND REINSTALL MS OFFICE TRY ANOTHER PRINTOUT. YES - GOOD NO - CONTACT MICROSOFT VENDOR. NOTE : NO PRINTER DISQUALIFIES ANY MS DOCUMENT.THUS ERROR FROM MS VENDOR.
Sep 17, 2007 | HP Deskjet F340 All-In-One Printer
HP PSC 1210 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
