Question about Kenmore Elite HE4 Electric Dryer
HE 4 Removing Heating Element
Kenmore Elite HE 4 - Once I am actualy looking at the Heater Element, How do I get it out. It won't budge and I can not see any screws that would be actualy holding it in place?
Also, I got to the heater element via front bottom panel, Am I correct?
  • 770 Answers
Post your email i will send you the manual on it.. also post the complete model number from the unit
Posted on Jan 26, 2008
I'm trying to change the heating element on my Kenmore elite he3 dryer.
Try grabbing the spade lugs with a pair of pliers and rock the lug from side to side while pulling.
Sep 13, 2014 | Dryers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Why does the heating element in my Kenmore elite look like it has a white film on it?
hard water. test water hardness, clean out with 8oz of CLR. and run affresh once a month for maint. ALWAYS RUN A FLUSH CYCLE AFTER ANY CHEMICAL
Oct 02, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Gas dryer kenmore elite runs but won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
HEATER COIL DOESNT WORK
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 25, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
How do I get element out of heater box on kenmoore 110.89683800. Box is out of dryer. Took out only screw I could find but still won't budge.
The last one I did it just slide out from the bottom........ Take a look at the new heating element and see if there are any holes or supports that you are not seeing on the old one that could be holding it in...... Hope this helps Good Luck
Jan 02, 2011 | Kenmore Dryers
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
Go to www.repairclinic.com and enter 417.98702891. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of various parts.
Mar 11, 2017 | Kenmore Dryers
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
Heating element
The model number you provided suggests that the lint screen is on top of the dryer, right? If so, the heating element can be accessed from behind the dryer by removing the rear panel. Of course, you should know this already since you stated you've already replaced the thermostat and fuse. The heating element is located on the right-hand side as you are looking at the dryer from the rear. There are TWO components on the heater housing. One is the high limit thermostat, one is a thermal cut-out. Are these the components you mentioned replacing? BOTH should read a short (0 ohms) when measuring resistance with the dryer turned off. If you haven't replaced both of them, double check to see if they are both good. The high limit thermostat will be located closest to the ceramic heater connection. The thermal cut-out will be mounted to the heater box. Perform a resistance check of the heating element as well. Measure across the leads of the heating element at the ceramic terminal connection. It should read between 8 - 13 ohms if good. If your readings prove that the heater is bad, it can be removed by using a 5/16" hex drive. The heating element should slide out the bottom of the heater box housing. Sometimes removing the heater box, and then removing the heating element is easier.
Your dryer is also equipped with an electronic cycle control board under the control panel that goes bad from time to time. This also may affect the dryer heating circuits. Inspect the small circuit board for any obvious signs of burned components.
I hope this information is helpful to you. If I'm wrong about your dryer configuration, please post back with comments, so I can give you proper instructions.
CAUTION: Make sure you UNPLUG the dryer prior to making any resistance checks. Dangerous voltages are still present with the dryer turned off.
PS I hope I'm not insulting your intelligence, here. As a rule, I tell everyone this information because some are not as savvy as others.
Feb 23, 2008 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
182 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
