that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
There might be a problem with your computer as well. Try printing with paralell cable to make sure the interface works at all. If the patalell-port works fine, try updating the printers firmware. Still problems ? Try with a different computer. If if works fine with another computer, then you know theres something wrong with your first computer. Good luck.
hi! there might be two possibilities...
1) the device drivers you have installed is corrupt.. try uninstalling n then installing the drivers
2) if that is not working out then your printer must be having some problem.. you may have to get it serviced.
