Question about ViewSonic VA721 17" LCD Monitor
VA721 Won't turnoff
I need a board but can't find one. None of the control buttons work and it isn't plug and play anymore. Viewsonic doesn't list a board anymore? I guess they don't support their products. They used to be respectable brand but I dont know what happen to them? I didn't realize when I bought it, it came with only a 1 year warranty? It lasted 18 months.
  • Anonymous Mar 05, 2008
    I have a similar problem. None of my ViewSonic VA721 controls work. On top of that,ti keeps shutting off at random -- LED goes out entirely, the screen goes black ... sometimes it turns back on, sometimes not (then I have to unplug it and hope for the best wen I plug it back in).
    Haven't found a solution. It just happened -- all morning it worked fine, then after I left the room for a second it stopped working. No idea what to do. Buying a new one, it looks like. Not ViewSonic, though.
Check for board and other parts on eBay.
Posted on Nov 25, 2008
The volume won't stay at the level selected. It counts itself down to 00. I hold the volume button to raise the sound but it struggles to go back to 00. The highest setting goes to 03. I have no...
Remove the TV from the power for a few minutes, and then power on, then check the volume, effectively you have reset the set. If it still will not work, check the manual for any sleep settings etc, and work through the setup again for the channels. Now if none of that works, and it isn't a remote control issue? Then unfortunately you indeed have a problem with the set and it will need to be serviced. it will most likely be a microprocessor and ambient background noise sensor or the like, this will have to be replaced. To this end get a "Quote" from a certified repairer, and go from there?
User and service and repair manual at links below....should you wish to DIY?
Oct 07, 2011 | ViewSonic N3250W Television
I have a whirlpool quiet partner i dishwasher (model DU1055XTSQ2) that has suddenly stopped working. Control panel has partial functionality. All of the buttons on the control panel have a green LED...
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Nov 14, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
The windows 7 is not recognizing the monitor VA721
May I ask what you mean by the windows does not recognized the monitor? You are not getting picture or you cannot set the correct native resolution (that is the best setting for best picture and aspect ratio)?
Native resolution for this monitor is 1280 x 1024 @60Hz.
And here is the common problem with VA721:
Mar 31, 2010 | ViewSonic VA721 17" LCD Monitor
I lost my installation CD for my ViewSonic VA721 monitor; can I get a download from the internet?
Yes here is a link to the drivers for your monitor>
Thank you for using
Feb 09, 2010 | ViewSonic VA721 17" LCD Monitor
I need a driver for my va721 monitor
ViewSonic VA721 VA721 Monitor Driver ... Login. Register ... Uninstall Windows drivers How to Uninstall Windows Drivers and why you need to know it
Dec 06, 2009 | ViewSonic VA721 17" LCD Monitor
Viewsonic VA721 - Screen goes blank for second or two and returns
Sounds like its going to sllep too soon make sure you do not have it set in your video card settings. also try it on a diffrent computer. if that does not shore it up replace the acpi board
Jun 11, 2009 | ViewSonic VA721 17" LCD Monitor
Dismanteling monitor/replacing backlight
Go to bottom of the page to download the PDF . It has complete instruction and pictures
Jan 07, 2008 | ViewSonic VA721 17" LCD Monitor
Viewsonic va721 monitor
Connect the monitor to a different computer system (if available) to see if the issue is with the video card or the monitor.
Make sure A/C power cord is securely connected to the LCD display.
Make sure the video cable supplied with the LCD display is tightly secured to the video
output port on the back of the computer. If the other end of the video cable is not attached
permanently to the LCD display, tightly secure it to the LCD display.
Your backlight may be going bad, or the small controller board may be going bad also.
Nov 29, 2007 | ViewSonic VA721 17" LCD Monitor
IBM LCD computer monitor is dim
Your backlight may be going bad, or the small controller board may be going bad also. You will have to contact ViewSonic for prices. It is not that difficult to change them out.
Oct 24, 2007 | ViewSonic VA721 17" LCD Monitor
ViewSonic VA721 17" LCD Monitor Logo
57 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
