Question about Freezers
Door gasket I have good door suction but high frost build-up at interior center top coil. Do I need to replace or adjust the door gasket?
  • fudge22 Jan 12, 2008
    Add to the above question: This is a whirlpool upright freezer model #eev202xw1.
  • Anonymous Dec 14, 2008
    got same problem
    Problem Solver:
  • 7 Answers
Try putting vaseline on the gasket. You are not getting a good seal.
Posted on Jan 17, 2008
6ya staff
SOURCE:
Refrigerator side frost build-up.
Every one of the issues the techs gave you are possible solutions.
Oct 13, 2016 | Continental Refrigerator Freezers
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Feb 12, 2015 | Frigidaire Freezers
Freezer door has mosture on the outside
You need to order and replace the door gasket. Also check and be sure there the hight adjustment is correct, meaning the door is centered on the opening and not off set to where it can seal.hope this helps
Aug 10, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
KFN 8862SD Fridge /Freezer The above unit is constantly building up ice on the fridge rear panel, despite having auto defrost! Help!!
1st stick a rag in the hole in the door (ice maker door) 99% of the time or o door gasket .... next ohm the auto frost coils to see if there in good working order, if they are it might be that you are low of freon. not a good sign
Jun 06, 2011 | Miele Freezers
I am experiencing frost build up on the top part of the door as well as the top part of the inside of the freezer. all other areas are fine
You have an air leak. Usually right where you frost build up is, however since hot air rises, sometimes this leak can be anywhere. Make sure your door closes tightly and your gaskets are clean and making good contact. You may have to adjust the gasket, adjust the door, or replace the door gasket. If there is ice on the floor of the freezer, you have a plugged drain line. In very rare instances we have found, where the freon lines enter the freezer, in the back or under the freezer, missing or fallen refrigeration putty that seals around the lines. Good Luck, Appliance Specialists
Jan 28, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer door is accumulating frost inside it at the very top. Frost build up has been occcuring for 7to 10 days and we have been removing it periodically. Freezer purchased on 6-23-05. The gasket appears...
The gasket is not sealing correctly and is allowing warm air to meet cold air just below the seal.
Get someone with more skill to fit a new gasket , preferably one made by the original manufacturer , which should fit unlike some of the parts made by third party suppliers
Jun 11, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Just defrosted my freezer and is akll frosted over
When you say it is frosted over, do you mean the interior of the freezer is frosted, or the evaporator coils?
A couple things to check for:
1. Is the door gasket making a good seal when you close the door? A good quick fix for a bad seal on the gasket is to rub a thin layer of Vaseline (the original jelly kind works best) on the rubber to help it stick and to fill any scratches that might be keeping it from sealing tightly.
2. Is the fan running on the inside of the freezer? The evaporator coil in the freezer needs a fan to blow air over the coils to keep them from freezing over. They don't run continuously, and on some units will turn off when the door is open, so try holding the door switch shut when you check.
3. Is the defrost cycle working? Frost-free freezers have a defrost cycle in which a small heater turns on to thaw any frost that has begun to form. To check the functionality of the heater and the defrost timer will probably require a visit from a technician... It would take a while to explain it here, but if check the first two and come up empty handed, post back. You will need a volt/ohm meter.
I would check the first two
Mar 24, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Mar 20, 2009 | Kenmore Freezers
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Jan 14, 2009 | Frigidaire 13.7 cu. ft. Upright Freezer...
Freezers Logo
257 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
