Question about Olympus FE-280 Digital Camera
Lens won't extend
My FE-280 won't let me take pictures. I turn it on but the lens won't extend. You can hear it trying but after 3 tries it stops. The lens cover open and shuts each try.
  • Anonymous May 09, 2008
    I have the same problem, the camera is on but the lens will not extend. Thanks for your help.
  • scurhan410 Dec 07, 2008
    i turn my camera on and the shutter goes in and out a few times and then it shuts off. will not let me even look at my pictures.
  • 97 Answers
A mechanism in the camera is broken or shifted. this is hard to fix byurself because so small and 2 dangerous trying 2 open urself. get to neighborhood electronics or a repir shop.
Posted on Jan 12, 2008
Card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
Help with the Olympus FE-280 8.0 megapixel, please!!
this is a tipically problem, of a pressure on the lens, if the lens go out. or if the camera are dopped. to resolve this problem alone you must have specifically knowledge.
the cost of the reparation is high. so if you want prove withe the exact model number, search on the ebay international seller the komlet lens with ccd for you camera. any american seller if you buy the lens, can give a guide to change the lens block. but this is not a symply job. if you make one error you loose the camera and the lens. the price of your lens block can go from 25 to 35 euro, if you can change it alone you have resolved with this money. ok.?? sorry for my bad english if you want help can you write me and i will help you
May 30, 2010 | Olympus FE-280 Digital Camera
Camera lens will not open, tries a couple of times, stops, tries 2 more, red light is on, then it turns off.
Some problem with the lens.
Was it impacted in any way or subjected to water exposure, sand or dirt?
Make sure the battery is up or new.
Sep 08, 2009 | Olympus FE-280 Digital Camera
FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Jul 02, 2009 | Olympus FE-280 Digital Camera
Jammed lens
If your camera is still under warranty, the best thing you can dois to take it to the nearest official repair shop and Olympus Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Olympus refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Olympus Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Olympus Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
Jan 29, 2009 | Olympus FE-280 Digital Camera
FE280Power button is pressed camera opens shutter closes shutter
- Bulgarian guide
- Estonian guide
Regards,
VOTIT
DONT FORGET TO RATE;
Jan 14, 2009 | Olympus FE-280 Digital Camera
Fe-280
I have recently had the same problem. I sent my camera back to Olympus who very efficiently repaired it FOC and sent it back with an extended warranty. I gather this is a very common problem with this camera.
Aug 01, 2008 | Olympus FE-280 Digital Camera
Olympus FE-280
1 year warranty on olympus products, but does not cover physical damage such as impact, water, or sand
Jul 18, 2008 | Olympus FE-280 Digital Camera
Lens stay out
Hey flakey61,
One thing you can try is removing the batteries, and according to the manufacturer if you leave them out for three days or more and then reinsert fully charged batteries the camera should reset to the default settings and this might resolve your problem. If that doesn't help this camera is most likely still covered under manufacturer warranty, and you could call the manufacturer and set up service on the camera. You can also bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out under manufacturers warranty to get serviced. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 13, 2008 | Olympus FE-280 Digital Camera
FE-280 Wont Focus and Shust Off
I have the same problem, but my display doesn't show anything. It is just black.
Dec 10, 2007 | Olympus FE-280 Digital Camera
Olympus FE-280 Digital Camera Logo
113 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
