Question about Toshiba 42H81 42" Rear Projection Television
The touch focus
The red will no longer align but mainly on the left side of the screen.
  • Toshiba Master
  • 8,617 Answers
Will the red align in all 4 directions in the other areas of the screen? If it moves in all 4 directions everywhere but one section its probaly a resistor near your convergence amplifiers. If the red wont move in all 4 directions anywhere, then its your Convergence amp ICs faulty. Cost about 20.00. Hope this helps.
Posted on Jan 13, 2008
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
Magic focus --blue and yellow sag in the upper left area of the screen
This is a problem with the convergence circuit. If you can solder, you can repair this yourself. First try and resolder the pins on the existing convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs.
Mar 22, 2008 | Hitachi 53FDX20B 53" Rear Projection...
57H81 rear-projection Toshiba red un-aligned
sounds like to me that you need to replace the convergence IC's.
Apr 06, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Screen Is Blurred
Did you try hitting the small button on the front of the tv labled flash focus? Try pushing this button because this model only features auto focus for aligning the red/green/blue projectors.
Nov 24, 2008 | Sony KP-53HS10 TV
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
Red is out of convergence
You can repair it yourself by replacing both STK392-110 Convergence ICs. You can get replacement ICs at the following link with free instalation instructions . Heres the link.
Aug 08, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 42H83 Touch Focus Problem
I just got finished repairing the same model . The convergence modules are bad cost of repair is 250.00 for a service center to fix. My advice would be call your local service center tell them what i told you bad convergence ic and ask them how much they charge,
thanks doctor video good luck since 1987
Jun 14, 2008 | Toshiba 42H83 42" Rear Projection...
LG rear projection colours out of alignment
This is all i could find when i did a search:
they have inherent problems with the glycol oil used to cool the tube leaking past the bladders & onto the boards.... & it's conductive :p
Dec 10, 2007 | Televison & Video
One of your convergence IC's has burned out and needs to be replaced. A good rule here is to go ahead and replace both STK392-110 IC's with the new improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits, allow a qualified tech to handle it for you.
Aug 12, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
