Cosco Juvenile Scenera Convertible Car Seat - Richmond Logo
Posted on Nov 23, 2009
I took the cover off of the Cosco Scenera carseat and can't remember where the latch straps feed from and through before connecting to the latches.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
964
Points
Go to www.coscojuvenile.com and download instructions or they will mail you some.
1helpful
Need instuction on how to reassemble safety straps on cosco car seat. I took apart to wash seat cover and don't remember how to reassemble
1. Find the same seat at your local store and take photos with your phone.
The position of the harness (slots in the plastic shell) is dependent on the height of your child.
2. Contact the manufacturer for detailed instructions
3. Find a certified Child Passenger Safety Technician or Instructor at safercar.gov.
What does cosco scenera model 22216-llp
You should see a harness strap over each shoulder that goes though the shell, behind the seat, and connects to a metal splitter plate.
The front of the harnesses (2) extend down though the buckle tongues then into the hip area of the seat.
There is a crotch strap that comes out of the shell where the child\'s crotch is. The buckle is attached to this strap.
There will be a LATCH (Lower Anchors and Tethers for Children) strap that goes through one of two belt paths. If used, this strap must go though the proper belt path.
Finally, there is a top tether strap the comes from the back of the seat - near the top - that will attach to the tether anchor in your car (see your car owner\'s manual)
My suggestion to you is to purchase a new seat. The protection of your child is most important.
Jul 10, 2014 • Baby Gear
How do we put belts thru and attach the brass latch on the back of the cosco scenera convertible transatlantic?? a pic of the bk of car seat would be helpful..
Here is the pic you requested. I am going to link to where I got it from as there was an issue (not a recall) with the harness getting cuts in it and I would like you to be aware of it. Being a parent I know how important those straps are. Hope this helps. http://www.car-seat.org/showthread.php?t=48028
I need instuction on how to reassemble safety straps on cosco car seat. I took apart to wash seat cover and don't remember how to reassemble
Here are the links to download Cosco carseat instructions:
Canada:
http://www.coscojuvenile.com/can/eng/instructions
USA:
http://www.coscojuvenile.com/usa/eng/Instructions
2helpful
Carseat model #22-248 wal how are is the straps
You can download manual for this model:
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583502A.pdf
For other cosco models, you can download the manuals from:
I have a Cosco Scenera.. how do i keep it from tipping. I have a '93 Buck LeSabre and no latch system.
its kinda tough being 1993 cars not having the back latch. The only quick solution to keep it tipping side to side, try using a square piece of plywood big and wide enough that the seat will sit on the flat surface and you have to use the center seat belt making sure its tight and secure to make it work properly.
5helpful
2answers
I can't remember how to put my carseats harness back together
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here are the links to download Cosco carseat instructions:
Canada:
USA:
Where do i attatch the straps in the back?
The straps that are attached to the seat are supposed to be used with the LATCH system that has been built into newer cars. You use the straps on the carseat to hook into metal loops under the seat instead of using the seat belt. If you aren't sure whether you have the latch system in your car or not, consult your owners manual or call a dealership and they should be able to tell you.
Top Cosco Baby Gear Experts
ZJ Limited
ZJ Limited
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
