Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Wireless key to set up DS & Wii ?
I apparently need my router key to connect my daughters DS and husbands wii yo yhe internet,how do I do that???
Thanks !
If you can, login to the router, then you can go to the wireless settings and get the WEP address. then you should have no problems. Usually you can get into the router by typing 192.168.1.254 from the main PC. Thats how I did my kids DS's and they both work fine. Hope this helps
Posted on Jan 27, 2008
    Novelist:
  • 139 Answers
If you don't have a record of the original key that was entered in the router, you could just completely reset the router and reconfigure it from scratch with a new wireless key. If the Internet connection goes through a cable modem or DSL modem, you can probably get by with this fairly painlessly...assuming you have the instructions and setup software.(?) If this router connects directly to a phone line or tv cable, then you'll need passwords and other settings provided by your ISP in order to reset and restore operation. Hope this is helpful...
Posted on Jan 12, 2008
HOW TO I GET MY WII TO CONNECT TO THE INTERNET
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection Settings."
5.Select "Connection 1: None."
  • If you do not have an empty connection slot, you will need to clear a slot.
6.Click on "Wireless Connection," then click "Search for an Access Point."
  • If using a wired Internet connection,
7.Select "OK." The Wii will display all the wireless networks it finds.
8.Select the wireless network that is yours.(If you're not sure which is yours, or you don't see any wireless networks)
Asked to enter a security key?
  • If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  • If you need to switch between upper and lower-case letters, or numbers and symbols, select the "Shift" key on the on-screen keyboard.
  • Ensure you review the security type in the top-left corner as well. If this is not the same security type that is used by your router, select "Change Security Settings" and select the appropriate security type.
9.Select "OK" 3 times to save your settings and start an Internet connection test.
  • The Wii console will run a connection test with your wireless network.
  • When the test is completed, you should see the following screen:
  • If the connection test succeeds, then your Wii is now connected to the internet.
  • The connection test was not successful, you will receive an error code.
    • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step eight (8) above for more information.
Don't know your routers security key?
Here's some:- A..To login into your Linksys router:
  1. go on this link: http://192.168.1.1
  2. The default username is: (leave blank)
  3. The default password is: admin
  4. Look for the security key settings. For Linksys routers, they are usually in "Wireless Security" on the "Wireless" tab or something similar.
  5. Find the selected WEP or WPA key, and write it down. Enter this number into the Wii or Nintendo DS when prompted.
B. To login into your Netgear router:
  1. Go on this link: http://192.168.0.1
  2. The default username is: admin
  3. The default password is: password
  4. Look for the security key settings. For Netgear routers, they are usually in "Wireless Settings" on the "Setup" tab or something similar.
.C.To login into your DLink router:
  3. The default password is: (leave blank)
  4. Look for the security key settings. For DLink routers, they are usually in "Wireless" on the "Home" tab or something similar.
Aug 18, 2017 | Internet Computers & Internet
Tip
How to connect your Nintendo Wii to the internet
In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
-Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
-Now select "Wii settings"
-Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
-Select "Connection 1: none"
-Select "Wireless Connection" then select "Search for An Access Point"
-Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
-Select the wireless access point you wish to use.
-If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
-Select "OK", then "Save Settings", and then "Yes".
At this point your Wii will now test the internet connection.
If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
I hope this guide has helped you connect your Wii to the internet. Enjoy!
Regards,
G33k
on May 13, 2011 | Nintendo Wii Console
Connecting netgear n150 to nintendo ds
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Jun 06, 2012 | NetGear N150 RANGEMAX 150 Wireless Router
Not connected to internet error code 51030
According to the following knowledge base article, this is a common problem. http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Please try the following steps in this order to try to resolve the issue.
1. Power off your Wii completely. Disconnecting it from any power source. 2. Unplugged your internet modem/router and wait for 10 seconds. 3. Connect your modem, wait for 10 seconds. 4. Connect your wireless router, wait for 10 seconds. 5. Power on your Wii and visit the Wii menu. 6. Test your internet settings.
If the error still persists, try deleting the wireless settings on your Wii. Then, recreate them after verifying that they are correct and match your wireless router's settings. If you need further assistance, follow the link to view a step by step guide provided by Nintendo to assist user's with connecting their Wii's to wireless access.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Jul 27, 2011 | Nintendo Wii Console
How do you set up Internet on the wii?
To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
1. Power on your Wii console
2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
3. Use the arrow on the right of the screen to move to page two, then select "internet".
4. Select "Connection 1 ' None"
5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Jul 24, 2011 | Nintendo Wii Console
Error code 51330. Internet connection via Wii
This error code means that your Wii is unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings
You can find more troubleshooting to resolve this at Nintendo's help database: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Mar 20, 2011 | Nintendo Wii Console
How to get internet.
You can try to connect to the internet wireless using your wireless router however, you need to know the Network Name (SSID) and the Network Key of your Router. You can find that on the router settings page. Heres how you can connect your Wii
1. Go to Wii settings
2. Internet connection settings
3. Search for an AP (Network Name or SSID)
4. Input security key (Network Key)
Thanks for using Fixya.
Jan 24, 2011 | Nintendo Wii Console
INTERNET CONNECTION
To connect the Wii to the Internet you will need a wireless router in your home. Otherwise, you have to buy Wii lan adapter to connect it with an ethernet cable.
To connect, go to Wii settings, then Internet, then Connection settings, then Connection 1.
Then click wireless connection and then let the Wii search for a wireless access point (a wireless router).
When your router appears on the list select it.
If your router has a key, then you have to enter it.
Press OK and you are finished.
Jan 30, 2010 | Computers & Internet
Nintendo DS vs. ActionTec GT704WG
Your DS may need another connection that is only blocked with a red lock. (Meaning WEP code locked.) If so, phone a computer tech support to help you set a connection with Wifi (wireless connection) and ask him/ her to set it to WEP code and "blocked". Then ask them to temporarily leave while you set your WEP password. A grey lock means that your DS is not compatible to your access point.
Feb 07, 2009 | Actiontec (GT704WG) Router
Wii connection issues.
You can check if the problem is with the internet connection going to the Wii or just the wireless connection.
When you loose connection, check the Wii's ip address. If it does not have an ip address(or ip is 169.xx.xx.xx) that means that the Wii is disconnecting from the wireless network. You can then try other wireless channels on your router.
If the Wii is still getting an ip of 192.168.x.x, that means that the problem is the internet from the router. You might need to forward ports on the router for your Wii.
Mar 13, 2008 | Linksys Wireless-G WRT54GS Router...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
