Computers & Internet Logo
Posted on Nov 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. I just tried importing my images from my canon 7d to my mac computer using the eos utility and it quit unexpectedly. I then tried again and any option I chose would reply with the word busy on the bottom right of the eos screen. Please help. I've tried various times to get it the eos utility to work but it doesn't import the images. I used another program (iPhoto), and it worked fine. This tells me that the camera is working fine but the problem lies within the EOS utility. Please let me know how to solve this problem. Thank you.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
601
Points
I have the same problem with my 7d using the EOS utility. What did you do to fix this? The problem has also caused the same thing to happen to Skype...
Mitesh Kr Anand
Level 3:
  • Master 497 Answers
  • Posted on Nov 23, 2009
Mitesh Kr Anand
Master
Level 3:
Answers
497
Questions
0
Helped
183969
Points
1465
Based on the information you provided, it seems that issue is with the EOS Utility itself.
Uninstall the EOS Utility, restart the Computer and then install the EOS Utility again.
This should resolve the issue.
If the issue persists, check for any update for the EOS Utility and install the update to resolve the issue.
Good Luck!!!!!!!!!!!!!
Dashlane desktop app quit unexpectedly on Macbook Air?
Dear friend,
Try to Repair Permissions on your Mac.
Go to Applications, Utilities, Disk Utility, Fist Aid, select your partition under your hard drive, and click Repair disk Permissions.
I'd like to put Canon EOS 7D video to iPad?
Like the 5D Mark II the 7D shoots H.264 codec. This must be compressed to a smaller size for iPad syncing or converted to a friendly codec for iMovie.
For iPad,
1. Transfer .MOV files to your Mac via USB.
2. Use Canon MOV Compressor to slow the 60fps down to 24 using frame controls.
3. Sync converted movies to iPad via iTunes
For iMovie,
Just convert Canon 7D to AIC for iMovie editing. iMovie supported best video format is AIC Codec MOV format, you can edit video with this format in iMovie smoothly without rendering,
Eos utility for canon powershot s5 is Mac Lion
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
I want to download HD movie clips shot on Canon 7D to a Mac. How do I do that?
Use a separate card reader to download to a folder you create on your desktop. From there, you can open them in imovie, Quicktime, or any other video program.
Importing Images
The CR2 suffix means that the picture was taken in the RAW file format, a proprietary format. This requires that the images be processed by a software conversion to be 'readable' by the computer. The EOS Utility software that came with the camera will work, as well as a number of third-party software packages. GOOGLE "raw file conversion Canon digital rebel" to see the options.
The other option is to take your photos in JPEG format (not RAW). Your computer can 'read' any JPEG format image.
Problem with EOS Utility
I have an Apple imac and a Canon 50D DSLR camera. I Loaded all the Canon "MAC" software on th imac. When Camera is connected to imac EOS Utility just "hangs". It just does not respond at all. Is fine of Windows XP machine but imac, nothing.
2answers
EOS Utility
Try not to launch the program from your computer just plug the camera to the computer and turn it on then the program will self launch and maybe all the functions will be avaliable.I hope it'll work
Switched to MAC - have EOS40D and SX100 - will not download SX100
Yes, you need to install the SX100 driver software as well. I wouldn't overwrite older versions of the Canon software, though, so do a selective install if you can.
EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
1helpful
EOS Utility does not Recoganize Camera
I am not sure about this matter but it seems there is a problem with your new computer. it might not recognize the usb cable.
try to plug your camera in another USB port and try again.
Top Canon Computers & Internet Experts
old marine
old marine
Steve Sweetleaf
Steve Sweetleaf
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
