Question about Canon CanoScan LiDE 25 Flatbed Scanner
Canon LiDE 25 scanner locked - can't unlock
The Canon LiDE 25 scanner has a lock switch on the
bottom. My scanner is currently unlocked. But, the
software says that the scanner is locked and I can't scan.
Perhaps the scanner really is locked and the switch
is broken. How do I get inside the scanner to fix this
problem. Maybe I just need to buy another scanner.
Thank you.
Paul
  • 7 more comments
  • Rabah2007 Apr 23, 2008
    canoscan Lide 25 is unlocked but the message box says that the scanoscan is lucked. I tried several times to disconnect the cable and lock and unlock the button but it didn't worked out. I would be glad if you tell how to fix the problem. Thanks in advance.
    the cost to repair the problem is more expensive than the price of a new scanoscan. Bye Bye
  • Anonymous Aug 13, 2008
    how can i fix the cable
  • Anonymous Oct 03, 2008
    I have the same problem with a Canon LIDE500F on a vista machine.
  • Anonymous Dec 17, 2008
    same problem
  • sopman Dec 19, 2008
    same problem on 2 Vista pcs. deleted and reinstalled software still says locked. But with ubuntu linux scanner worked immediately when plugged in . recognised scanner with no problems. Did not need to install anything!!
  • mynwo Dec 21, 2008
    i have this problem with a 600f which i bought to replace a 300f which did the same thing. i thought the 300f must have been knocked, but the 600f has been used just twice.
    will never buy from canon again
  • Anonymous Jan 19, 2009
    We own several of the Lide 25 scanners. They all have the false locked message problem, no matter what PC. Vista, XP, linux it dosn't matter. These scanners are cheap for a reason.
  • Anonymous Mar 22, 2014
    Scanner locked
Posted on Jan 20, 2009
CARD IS FAULTY
Posted on Jan 30, 2009
    Scholar:
  • 111 Answers
Try the scanner on another computer to verify that it is not just a conflict on that particular computer.
Posted on May 08, 2008
6ya staff
SOURCE:
Iam getting problem with canon lide 25 scanner give eroor message unlock detach i/f cable
hi. there is a small lock slide in the bottom of that model. be sure it is in the unlock position
Apr 28, 2017 | Canon Office Equipment & Supplies
Canon CanoScan LiDE 100 Flatbed Scanner Release lock switch
Beneath the scanner is a lock switch, ensure that it is in the unlocked position.
If it is in the unlocked position and it still displays this error message then you will need to get a technician to free the reader assembly and give it a clean. Not too big a job. It's a good little scanner I enjoy mine, even after the same thing happened to it.
Take care!
damnor01
Nov 01, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I cannot use scanner Lide 25.. because show error : "release the lock switch,detach the I/F cable and reconnect" How solution?
Sounds like the scan head is locked. This is usually done so you can transport the scanner without bouncing the scan head out of alignment. Look under the scanner and you will see it. Make sure it's in the UNLOCKED position. You may need to power the unit off/on to reset it or restart your computer to get a fresh attempt at the scanner.
Mar 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Release the lock switch, detach the I/F cable
try this
1. at the back of the scanner there is lock try to release that one (slide to unlock)
2. uninsall the system and re-install again
3. check the usb port of your computer
thanks
Feb 18, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
2,628 people viewed this question
Clive
Clive
old marine
old marine
Ekse
