Question about Kyocera Finecam S5 Digital Camera
Zoom lens/flashlight don't retract.
Zoom lens and flashlight refuse to retract. I have recharged/reinstalled battery, but lens keep staying open and the camera doesn't work. Warranty expired. What shall I do? Thanks!
Replace zoom lens strip and please do let me know where it is available I too have the same problem
Posted on Apr 16, 2008
6ya staff
SOURCE:
I couldn't open the camera. when im trying to open it it shows and error message on screen "zoom did not operate correctly...."
Digital cameras with shutter covers sometimes jam, keeping teh cover from retracting and the lens from extending. That is what is giving you the message. You may be able to assist it by gently pushin it open when you turn on the camera. Key phase there is "gentle". Do not force it open as you may permanently damage it. If the motor is locked up or the lens cover still refuses to open, take it to a camera shop for service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Dec 23, 2014 | Cameras
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
My batteries run out on my samsung d1070 camera and now the zoom is stuck and the camera wont turn on it just beeps
I suggest that you place the camera in a safe place ware the extended lens will not be damaged, than remove and recharge the battery. After replacing the battery, the lens should automatically retract and you should be good to go. Hope that this helps, God bless...
Aug 16, 2009 | Cameras
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Jul 26, 2017 | Konica Minolta Zoom 160C Date 35mm Point...
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse. Good luck!
Sep 11, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Battery problem
It probably lacked the power to retract the lens. I'd start with recharging the battery and see if that corrects the problem.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Kyocera Finecam S5 Digital Camera Logo
145 people viewed this question
Top Kyocera Cameras Experts
Ekse
Pat McCabe
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
