Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 Green distortion
TV was working fine and all of a sudden the green image is totally warped and out of alignment. This is not something that can be adjusted through convergence process. Assume it's a part that went out of whack. Green image actually bows in from top and bottom.
  • mim3 May 12, 2008
    Purchased 12/01. Same problem with green out of alignment.
Had a TV repairman replace the convergence circuit board. Total cost... $670. Cost of new 52"... Divorce court!
Posted on Feb 07, 2008
    Scholar:
  • 90 Answers
Replace the conv ICs.
Mr Bob
Picture is always dark
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Mar 18, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
My picture appears to be out of convergence but i cannot adjust it back. Looks like the green is off a couple of inches.
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5, STKs changed, getting blue screen but not pict
Did you have double image before changing the stk's ? If not then there was no need to change them.. Pioneers are known for bad solder connections especially in the power supply section.. suggest checking that when you changed the stk's that there are no solder bridges between the pins of either stk ICs
Dec 22, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
MITS WS-65869 The green CRT is creating a warped image.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Power problem (switches to standby)
its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
thanks.
May 19, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red and Green picture with ghost images
sounds like the high voltage transformer arc or one of the picture tubes arc causing the convergance ic to go bad
you can try to replace the IC heres a site to help:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
but you still may have a arcing problem.
Dec 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
166 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
