Procedure for replacing fluid in our rear projection television
We are going to order the gylcol oil to refill the tube in our tv and need the procedure on how to do it. Also any do's and don'ts would be helpful.
  • 372 Answers
Changing Projection TV Coolant
1. Tip the TV set so the expansion chambers are pointed up. The expansion chamber is a small white/clear plastic bulb-like thing
that is attached to one side of each of the CRT's up near the top lens. In some TVs, the expansion chambers are already pointed
up - In this case you don't have to tip the TV.
Or if you find this difficult remove all 3 CRT tubes from the metal cradle they are screwed to & lift each tube completely out you will need to unplug & disconect all leads from the crt.
2. Cover the circuit boards below the CRT's with several paper towels to prevent accidentally spilling any coolant onto the boards.
The coolant is corrosive and will destroy the circuit boards. Don't skimp on the paper towels here - they are cheap!!!
3. Remove the four screws that hold on the focusing lens assembly and remove the focusing lens assembly.
4. Note the position of the expansion chamber then remove the expansion chamber. It will need to be reinstalled in the exact
same position so remember the position or take a picture if you need to. There is a small o-ring on the neck of the expansion
chamber where it threads onto the CRT housing - Don't loose it!
5. Use the baster and tube to suck the fluid out from the hole where the expansion chamber was removed. This hole is fairly small...
maybe 5/16" or so.
6. Once most of the fluid is out, remove the four screws that hold on the lens cover plate.
7. Remove the lens cover plate, the lens & the large o-ring. (be gentle with the o-rings!!!)
8. Clean the CRT chamber & lens with denatured alcohol. Use 100% cotton balls so you don't scratch anything.
9. Clean the CRT chamber and lens with distilled water. Again, use 100% cotton balls so you don't scratch anything. This will rinse
out the alcohol residue. You need to use distilled water for this so there is no mineral residue.
10. Gently clean the large o-ring with distilled water (don't use the alcohol because it might eat the o-ring) Dry off the o-ring and
lightly coat it with 100% pure silicone (not siliconized acrylic caulking or acrylic latex caulking - ONLY USE 100% SILICONE).
Use your fingers to rub a thin layer of silicone all over the surface of the o-ring. Then place the o-ring in the groove in the CRT
housing.
11. Place the lens in its position on the o-ring.
12. Place the lens cover plate over the lens and install the four screws.
13. Clean your baster and tubing with denatured alcohol then rinse with distilled water.
14. Use the baster and tube to suck clean fluid from the bottle and install it into the CRT through the expansion chamber hole. Go
really slow when it is almost full to minimize overflow. Wipe up any overflow immediately. There will be a small air pocket in
the CRT when you are done - you will not be able to fill the chamber 100% - This is O.K. Just be sure to fill it as far as possible
so the fluid is just up to the edge of the expansion chamber hole.
15. Install the expansion chamber. Be sure to install it in the same position as it was before you removed it. Also be sure that the
small o-ring is on the neck of the chamber before you thread it on. The chamber is just plastic so don't over-tighten it or you
might damage it. Screw it on as tight as you can go by hand and then give it about 1/8 of a turn with pliers. (you might have to
use needle-nose pliers to get a good grip on it.)
16. Place the focusing lens assembly into position and install the four screws.
17. Turn on the TV and check for leaks over the next 20 minutes. Remember, you have not yet removed all the paper towels from
inside the TV. Remove these once you know there are no leaks.
Other things that should be done after replacing the fluid include...
1. Clean the mirror
2. Clean the top lenses of the focusing assemblies
3. Focus the CRT's
4. Adjust the convergence
Here is a list of things you will need:
1. Turkey baster
2. Vinyl tube
3. Cooling Fluid
4. 100% cotton balls
5. Paper towels
6. Denatured alcohol
7. Distilled water
8. Pliers
9. Screw driver
Ensure you use only the coolant made specificaly for projection CRTs
http://dysonmanuals.llc.nu/
Chris..
Posted on Jan 13, 2008
    New Friend:
Changed coolant but now have no picture or sound
Posted on Jul 04, 2010
    New Friend:
Can i transport a rear projection TV laying on it's back with the screen side up?
Posted on Jan 15, 2010
  • 8,617 Answers
See my solution to the post "need to replace glycol oil (Coolant)
I have outlined the entire proceedure there. If you cant find it let me know and i will repost it here for you.
6ya staff
SOURCE:
I have a bacterial growth in the blue bulb heat sink fluid container. can i get replacement fluid and change it out?
Go to either newark .com or MCM.com and order projection TV coolant to replace the ethylene glycol that has become contaminated. Good luck this is a very difficult and time consuming procedure.
Jun 15, 2010 | Samsung HCN653W 65" Rear Projection...
Oil from lences leaked out and got on al the chips and wires what do i do
This is projection tv coolant. You need to clean all region on board where the liquid leaked and remove the tube who leak and flush the coolant. after good cleaning of tube and lens, reassable them and refill with new coolant.
Apr 22, 2010 | Sony KP-53HS30 53" Rear Projection...
COLOR IS DIM & THERE IS NO RED COLORINGS, WOULD THIS BE A BULB? EVERYTHING WAS FINE UNTIL WE GOT THE HDTV SET UP. THE DVD MOVIES SEEM TO WORK FINE.
The red crt tube on your tv is going, or you need more optical fluid for the lens. Crt tubes typically run for $150-$300, and a fluid refill should be less than $100. If the tv isn't very clear or bright, even when working right, then consider just getting a new tv. These are costly to repair and will eventually begin to have more problems.
Contact me for more info.
Thanks for asking!
-Josh
Feb 26, 2010 | Mitsubishi WS-55809 55" Rear Projection...
What kind of fluid goes in the lamps of my toshiba 57h82 rear pro sceen tv
It is a Optical Grade Cooling Fluid that is pretty much standard in most Rear Projection CRTs. It can be purchased from Electronic Parts Wholesalers such as Encompass Elect. Their phone number is 1800-638-3328. Toshiba does not have a procedure for refilling or replacing the fluid due to it's toxic nature. It is absorbent to the skin and you do not want it in your body. If the fluid leaked out of the CRT, the seal of the Optic Coupler has failed and it is not replaceable according to Toshiba. The CRT must be replaced. Encompass Elect would also be able to help you get the right CRT. It will be a expensive part. I estimate it to be around 300.00 to 400.00.
If you do choose to do it your self , I recommend to get a Service Manual down loaded from toshiba.com
so you have a dis assembly and reassembly chart.
You will also have a Convergence Procedure you will need to go through for the CRT you are replacing in both NTSC mode and HD mode if applicable.
I hope this helps,
Skyassoc
Nov 12, 2009 | Toshiba 57H82 57" Rear Projection...
How to change crtfluid
Only a qualified service tech should replace coolant fluid. I've serviced TV's for a good while, and I would not attempt this repair without a co-worker showing me precisely what to do. You have to remove the Picture Tube(s) to do this, and if they leak after assembly, your TV circuit boards could be totalled out. The coolant is similar to anti-freeze and is corrosive.
Apr 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Fluid in len leaks out
Hello grace11112,
First I have to say that the fluid is what keeps the tube cool, if you use the TV without replacing the fluid, the tube will eventually burn out. Now the fluid has to be replaced, I would suggest that you have a qualified TV technician do this. The fix for this problem is to reinstall the seals on the tube refill the coolant, and reinstall the tube. Coolant can be purchased from the manufacture or from a parts supply store.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Foggy picture
That is your coolant projection fluid make sure you clean up any that may have went on chassis ect.....refill fluid in lense make sure it does not leak and try again, tube should be same as before, when chaning fluid in lenses always turn set on look into lenses if clear it is ok if dirty looking then change fluid.
Dec 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Need to replace the glycol oil (coolant) in our rear projection tv
You can get The Picture Tube Coolant at the link here Matt electronis. they offer quick shipping, And if you need instructions on how to do the proceedure , please let me know
http://www.matelectronics.com/cgi-bin/ss000001.pl?SS=coolant&PR=-1&TB=A&SHOP=&ACTION.x=16&ACTION.y=9
Jan 12, 2008 | Televison & Video
HCN653W Yellow tint and perfect focus.
yellow tinting is a indication of browning or alge growing in what is known as crt fluid also know as glycol. although this can occur in any of the three tubes blue is your most likely tube. dirty gylcol can be changed. but is a involved repair. you have to remove the tube. remove glycol disassembel tube clean thoughly with denatured alchol. reassemble fill with clean fluid ..replace tube then align and reconverge. as a tech aournd a 2 hour job
the dirty glycol can also cause the perfect focus to fail as the sensors cant "see" through the fluid. this is a very common problem on these units
Jan 08, 2008 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
1,362 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
