Question about Tomtom GO 910 GPS Receiver
Using with Verizon?
I have sev. probs with the Tom tom and I'm trying one solution to fix one of the errors but I cannot figure out how to get this one working:
When I connect via bluetooth it shows the bond request from my Krzr K1m phone and the Tom Tom multiple times. I'm using verizon but not verizon's firmware so my bluetooth capabilities are fine. still, I cannot connect to the device easily and when I do connect, text messages are disabled.
Also, I do not know how to use any sort of wireless data connection with the Tom Tom and my phone. Is it even supported? I tried KRZR k1 but that's a GSM model so I'm not sure that will work. Verizon is not even listed in the choice for carriers.
Any help?
Try here some phone features are not supported via tomtom
http://www.tomtom.com/phones/compatibility/
Posted on Feb 20, 2008
My tom tom one when i swith on the screen shows the sd card being removed from tom tom with a red cross across sd card.the sd card is in side .i can not past this screen or use gps how do i fix thanks
It is likely that the SD card (data) is corrupted. I'm assuming that it had previously worked properly.
Have you tried running a (fix) disk utility against your (internal disk or SD card) storage for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 24, 2013 | Tomtom One XL GPS Receiver
How do i get fix my tomtom one 3edition from looping
My solution after probs with 2 different units: Buy a Tom Tom. I did and it works great.
Mar 11, 2010 | Tomtom ONE 3rd Edition GPS
TomTom Navigator 6 and HTC Touch Pro 2
Start
Settings
System
External GPS
Programs tab - select COM4
Hardware tab - GPS hardware port = (None), Baud rate = 4800
Access tab - Check the box for "Manage GPS Automatically"
Hit OK
Then open TomTom
Touch the signal bar then the signal bar again
OR
Go to Preferences then Show GPS status
Hit - Configure
Select - Other NMEA GPS receiver
Ensure the baud rate is set at 4800
hit Done
Select COM4:
Feb 16, 2010 | Computers & Internet
My Tom Tom 920 will not stay on the map screen for more than a few seconds.
Its sounds like a problem with the screen then. If it is still under warranty, return it
Feb 13, 2010 | Tomtom GO 920 GPS Receiver
I think I deleted the actual program on my tom tom ONE 130! It will only give me an orange screen with a red X and a flashing disk in the bottom left hand corner now. What can I do to fix this?! ?!
If you wisely made a backup of your device using 'Tom Tom Home', use the 'RESTORE' option!
Otherwise try 'Tom Tom Home' while connected to the Internet and select 'Update' my One: it should re-load and update all missing components (including the MAP) that your machine is allowed to have.
Dec 25, 2009 | Tomtom ONE 130 GPS Receiver
No Sound coming from my Tom Tom One.
try swithching device off then back on. tap volume bar at bottom. if this does not work reset device by using small pin in base of sat nav, this is underneath and is a small hole which says reset by it.
Good luck and please feel free to rate my response.
John
Sep 03, 2009 | Tomtom ONE GPS Receiver
TomTom One GPS fault
I had the same problem after downloading the latest maps, the unit was slow to boot up and would not find any satelites. I had no response from e-mails to Tom tom tech support and I was going to give up and buy a new device if this fix failed. I had tried paper clip resets and resetting to factory settings but they had not worked.
After reading the previous answer to this link I searched Tom tom support for 'clear flash' and the search results were more useful than the FAQ on the normal support pages.
I used Tom tom home to uninstall the current software application and then reinstalled the latest version (I had to go through several updates as my version of the software was from when I purchased the unit in 2007), I then downloaded and ran Clear flash and made sure that I disconnected the tom tom from my PC using the correct procedure (using the eject button in the bottom of the tom tom home screen as I read that this could have contributed to the problem in the first place).
After another reset the device came to life and after a few minutes searching for satelites outside the device worked as it should (try checking the configure GPS option if it is taking a while to find a signal, it could be just me but it seems to speed up the search process).
Hope this helps.
Apr 07, 2009 | Tomtom ONE XLS Car GPS Receiver
Getting my phone to see the GPS signal
Can I Install any other language fonts other than than english
Feb 11, 2008 | HTC Touch P3450 Smartphone
Tom Tom
I have a similar problem also. I bought a new unit with speed cams installed, the software advised to update the unit, on completion of the update it removed all the speed cams!!! tom tom said it was a bug in the update and to wait till now 26/10/07 for the fix. I have tried to download the fix, but this crashes at 99% install. and advises an error on my E drive which is the tom tom. suggest you try as my card may also be faulty, this may correct your fault
Cheers
Oct 14, 2007 | Tomtom ONE GPS Receiver
Tom tom download probs
You need to be a subscriber for updates.
Sep 14, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 910 GPS Receiver Logo
143 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
