Question about Panasonic PT-47WX53 47" Rear Projection HDTV
BLUE AND YELLOW
When watching tv- parts turn blue and yellow - usually around the outline- Is this a bulb issue and if so how do I get parts
  • kaliu2fan Oct 28, 2008
    The other evening my Panasonic PT-47WX54J lost its picture- sound is perfect but we have vertical wide lines going through it, what can this problem be and is it worth fixing?
  • Panasonic Master
  • 8,617 Answers
If you go to the following link we have the service manual for your set for 10.99 and we offer unlimited chat support to help you diagnose and repair your set. Just click on the panisonic link. If you click on the contact us link and provide your email address we will email the manual right out to you along with instructions on how to enter into chat with us. I am one of their support Techs. Hope this helps.
http://servicemanuals.vstore.ca/
Posted on Jan 13, 2008
My toshiba 57H82 tv has double image blue and yellow
This is a known issue with the model that you have listed. The repair kit is here: http://www.tvrepairkits.com/xcart/57h82/ You should be able to solder, the kit comes with diagrams, photos, parts and support.
Mar 07, 2014 | Televison & Video
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
MY TV NOW SHOW BLUE AND YELLOW AT THE TOP AND
i have a 52 in rca tv and i turned it on and now there is a blue and yellow stripe at the top and bottom of the tv. and the people have a blue shaddow around them ? how can i fix this?????
Aug 25, 2009 | Hitachi Televison & Video
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Sony KP-51ws500 Sagging Picture and blurred colors
Bad convergence Amp ics mounted to large metal heat sinks on deflection bd.Sony parts around $40.00 each-generic approx 12.00 ea.The board must be pulled out of chassis frame to unsolder the ICs.and some alignment will be needed after replacement.NOT a do it yourself job unless experienced at soldering and desoldering.
Jan 04, 2009 | Sony KP-51WS500 51" Rear Projection...
Yellow and blue on screen
I am slightly confused about the model of the television, because a 46F500 is a rear projection set that doesn't have a lamp. It has 3 picture tubes and I have a few of them in my shop right now that have the problem you reported. What we do to this set when it develops a convergence issue is to check each resistor around the convergence chips for discoloration, and replace any of them that have changed in value, along with the STK392-150 ic's. If you don't have an ohm meter and solder/desolder equiptment, you can usually get a shop to do this repair for 150.00 to 350.00. Parts will be 50.00 and labor , the rest, depending on the quality of repair shop that you use. Good luck, Russmann.
Nov 16, 2008 | Hitachi 46F500 46" Rear Projection...
Yellow/blue outlined image while viewing
reset the settings to factory default. the resolution and phase is off. also make sure the projector is not too close to the screen.
Nov 29, 2007 | InFocus LP 735 Multimedia Projector
Powers Out and Power light blinks 3 times
If the picture turned yellow then that usually indicates a loss of blue. The blue CRT might have shorted out or the driver to it. The driver will be the lesser of cost in repairs.
Apr 17, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
