Question about GE WWSE5200B Top Load Washer
Clothes caught under agitator
Have a Hotpoint WLW5700B top loader washing machine (year 1987). Clothes have become hung under agitator. Looking for proper way to remove assembly to free clothes.
  • 641 Answers
SOURCE: GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Posted on Aug 27, 2007
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
  • 163 Answers
SOURCE: Top agitator not working properly
you need to replace your agitator dogs in agitator.very cheap fix and easy repair.pop the top off agitator,you will see 1 bolt inside center of agitator,take out bolt and pull agitator.pull agitator apart and in the top part you will see 4 plastic dogs.
Posted on Mar 05, 2009
  • 544 Answers
SOURCE: washer will not agitate or spin
you can view this site to have some ideas about your agitator problem.
any further question let me know.
Posted on Mar 29, 2009
  • 5 Answers
SOURCE: thumping hitting front stops on wash cycle.
if it was not NEW and under warranty, you bet i would ask for your paid service in heartbeat.
the repairman is arriving finally tonight.i will update what he finds.
Posted on Apr 06, 2009
How to install agitator?
On a top loader, the very top of the agitator will pry/pop off. Inside you'll see the "agitator dogs" These are what cause the agitator to grab and wash the clothes. Under the dogs you'll fine a small bolt that holds the agitator blades onto the drive shaft.
Aug 18, 2014 | Kenmore Washing Machines
How do I remove clothes from under agitator?
Believe it or not the agitator will come off. Look under the fabric softener cup. There should be a fastener (nut or bolt) to loosten. Give the cup a good cleaning while you have it off.
Once the nut is removed you can work the agitator off.
Jul 27, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Top Loader Fisher & Paykel agitator makes banging noises when washing clothes
its common on these machines especially the bigger ones,chances are the suspension rods are worn out and need replacing
Jul 03, 2014 | Fisher and Paykel Washing Machines
Why does my clothes get stuck around the bottom of my agitator during washing?
the center of your Agitator has a cap or a pull off top inside you should have a Nut, Tighten the nut back down sounds like the plastic Agitator has lifted up and has to be tapped or tighten back down into the Tub.
Mar 15, 2014 | Hotpoint Washing Machines
Fine garment caught under centralrotor has black mark on it , is this grease?
It is not grease. Under the agitator there will be a sticky buildup of detergent and dirt that has stuck to it. Overtime this buildup can become quite a lot. When your garment became caught up under the agitator, it was becoming stained with this buildup.
Jan 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Apron caught under wringer
Hi Karen,
That is a real pain when that happens, but let me see if I can help.
First on the top of the agitator or wringer you will see a small cover. You will need to pop that off to reveal the screw hidden underneath. Remove the screw and then the agitator will pull upward and off. The agitator on the hotpoint washing machine is really hard to pull off so you will really have to pull. When the agitator comes loose you will ofter be pulling so hard that you could hurt your arm on the top of the tub so be extra careful or get some guy to get hurt for you. Once removed I am sure the apron can be easily removed and all will be well again. Good luck to you and please dont forget to rate me. Have a nice day.
Mike Anderson
Anderson Appliance Repair
Oct 28, 2008 | Hotpoint Washing Machines
Washing Machine
If your machine uses a washplate or agitator there is one 7/16 bolt under the center cap or fabric softener dispenser. After this a agitator will lift from the bottom and a washplate will need assistance by grabbing the basket and lifting quickly to pop the washplate up so it can be grasped.
Oct 15, 2008 | Kenmore Oasis HE 27082 Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Hotpoint washer
Two types of Hotpoints had two different ways of removing the agitator. One had a pop off top that when you removed it, you can remove the center bolt, the remove the agitator. Another one you had to put your fingers under the agitator and pull straight up to unclip the agitator. Good Luck!!! Jim
Sep 04, 2007 | Washing Machines
GE WWSE5200B Top Load Washer Logo
174 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
