Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Almiral I have almiral refrigerator 10 year old I put the new icemaker and no work My Email [email protected]
  • Anonymous Aug 20, 2008
    I HAVE REPLACED THE ICE MAKER ASSY THE WATER VALVE ASSY AND THE DE-FROST T/STAT. I HAVE POWER ON THE RED WIRE GOING INTO THE ICE MAKER WHEN CHECKED WITH A SINGLE POLE TESTER. WHEN TESTING THE TEST POINTS AT THE ICE MAKER "L"AND "N" MY TESTER DOESN,TLITE UP BUT WHEN I GO BETWEEN "L" AND "V" IT LITES UP. DO I HAVE A NEUTRAL PROBLEMAND IF SO WHERE WOULD YOU START LOOKING.
    THANKS PETER
  • 770 Answers
Check you water inlet valve in the back right side behind the cover
Posted on Jan 24, 2008
6ya staff
SOURCE:
How can I get my original facebook page back due to bellsouth.net address is no longer available and I had to change my email address. Please help My email address with with bellsouth,net. They have...
Hi brenda_dorse,
Here are some useful instructions on how to revert back to the original layout of facebook.
1. Click the link below and add the application.
http://www.new.facebook.com/apps/application.php?id=2345053339
2. Wrap it all up by clicking the next link below.
http://apps.new.facebook.com/?fbnew_opt_out=1
-If you accidentally navigate back to the new Facebook just re-click the second link. (save it somewhere)
-Many have recommended logging in and out to confirm it.
Sep 30, 2011 | Facebook Social Network
Hotpoint ref'r icemaker does not work.
I defrosted the freezer, overnight. After turning it back on in the AM it worked.
Feb 20, 2009 | Hotpoint HSS25GFP Side by Side...
Sending email from Microsoft Outlook to Bellsouth.net
Are you including the @bellsouth.net on the login screen ? Let me know if this helps :)
Dec 16, 2008 | Microsoft Office Outlook 2003 for PC
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Hotpoint side by side icemaker
Dear friend,
ngfam at you service! happy to assist!
STILL NOT WORKING??????????
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 19, 2008 | Hotpoint HSS25GFP Side by Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Ekse
jasbo
jasbo
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
