Question about LG LH-D6230 System
I bought my DVD player over from the uk, and cannot play Australian DVDs, I have been told I need a software upgrade via cd but don't know where to get it from??? please help
  • mcdclan Jan 02, 2009
    have a dvd lg model v217 and can not play my UK/USA dvd's
How can i buy a new remote controler
Posted on Aug 09, 2010
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Posted on Mar 23, 2008
Is there a way to change the region code on a Sony HCD-S300 Please?
Unfortunately, you have a DVD player that is "Region Specific" and cannot be changed. Your system has a region code printed on the back of the unit and will only play DVDs that are labeled with identical region codes. DVDs labeled "ALL" will also play in this unit. If you try to play any other DVD, the message " Playing this disc is prohibited by area limits." will appear on the TV screen. Depending on the DVD, no region code indication may be labeled even though playing is prohibited by area limits.
Mar 26, 2012 | Televison & Video
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
Cannot record t.v. programmes after the changeover on video
I put the recorder channel on AV2 and then recorded it. It worked. Thank you anyway.
Dec 29, 2009 | Samsung SV-DVD55 DVD Player / VCR Combo
Audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
May 11, 2008 | LG LH-D6230 System
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Jan 16, 2008 | LG LH-D6230 System
Dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
Nov 03, 2007 | Televison & Video
'Where can I get an LG optical pick-up for the LG LH-D6230 DVD player?
Easy and inexpensive to repair. not laser at all. disks are not spinning at the correct speed, clean the round rubber seal that pushes against the disk with 100% alchohol.
Apr 19, 2007 | LG LH-D6230 System
Try this:
Apr 18, 2007 | LG LH-D6230 System
LG LH-D6230
The life of LG optical pick-up is Aprox.1000hours if it is more then 1000 hours used then just replace optical pick-up.
Feb 07, 2007 | LG LH-D6230 System
LG LH-D6230 System Logo
838 people viewed this question
Top LG Audio Players & Recorders Experts
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
