Question about Technics SL-1210 Turntable
Turntable power seems to be lightly surging
The light under the on/off switch is blinking slightly when the table is turned on. I can hear how the sound of the record is being affected at the same time the light blinks. I have a CD tuntable hooked up to the same power source and that is working fine. What could be causing that power to be surging like that? The table is brand new out of the box 3 days ago. Thanks in advance!
    Novelist:
    Champion:
  • 382 Answers
Sounds like a voltage regulator on the mothboard is going out. Avoid going in there, you really could fry yourself poking around in there. Check out these guys. They're top notch
http://www.repairnyc.com/
And Technics authorized.
Posted on Jan 14, 2008
My Optimus LAB 1100 is playing 45s ok but the 33s sound like the chipmunks
the turntable speed is incorrect
adjust with the speed control setting
many quality turn tables have bar codes around the outside edge and when viewed under a light those bars appear to be stationary when the correct table speed is set
It is a strobe affect in time with the frequency of the light
Dec 06, 2015 | Audio Players & Recorders
Just bought an Anders all in one player. The 33 1/3 speed is slightly slower. Cannot seem to get it to run correctly. any ideas?
If it is a fairly cheap unit there may not be an area where you can adjust the speed of the turn table
on better machines there is a variable rheostat where by you can adjust turntable speed
quality machines will have the edge if the turntable marked with what looks like bars
This is not decoration but when viewed under a light bulb will appear as stationary bars when running at the correct speed or as a blur when at the incorrect speed
It works like this
the bars are in effect a strobe that is affected by the light frequency or power hz so that when the strobe affect is exact the bars appear stationary
( like disco strobe )
so if your player has these bars on the edge , then check the actual speed with a bulb light Remember stopped bars is exact speed
If the turntable doesn't have these bars then most good home entertainment shops will have a paper plate that can be put on the turn table and the effect will be the same
other than that talk with a good radio repairer shop and have the variable control installed in the power circuit for the turntable motor .
Jul 23, 2015 | Audio Players & Recorders
KDS-R60XBR2 No picture, no sound but solid green light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
I can not hear what is being recorded to my pc from my ion turn table but I can hear the playback after
Probably something to do with the control panel of your computer sound system. You might have got one of the controls turned down or switched off.
Sep 10, 2013 | ION Audio iTTUSB Turntable
I have an 02 kia sportage. my signal lights come on but dont blink outside. no lights for the signal lights come on on the dash at all. also, no hazard lights.
If the 15A HAZARD fuse in the passenger compartment fuse box is OK, power is getting to the hazard function of the flasher unit. Pressing the hzard switch should cause the hazard lights to flash. HOWEVER, there is an electronic time and warning indication system module connected to to the hazard switch lead and that may be affecting things. If the 10A TURN fuse is OK, power is applied to the turn switch (with the engine in START or RUN) and you state you can select a right or left turn. HOWEVER, the RED/WHT and RED/BLU outputs from the flasher unit connect directly to the front and rear turn lamps and the instrument cluster turn indicators so you are not getting any flasher output. Again, that electronic time & warning indication system module could be affecting things
Oct 26, 2012 | Cars & Trucks
OK, I just bought this second hand dp 01 fx, so I hjave to be humble but : does it record or not ? In (suposedly) record process, I can hear the piano in the phones, see the sound level on the screen, but...
Digest the book. We can't answer every question in real time and THERE WILL BE MORE QUESTIONS.
If you get the book in an electronic form you can search it faster.
http://tascam.com/content/downloads/products/352/dp01_dp01fx_manual_e.pdf
Search the web for "tascam dp-01fx driver" and many other questions you may have.
Jul 19, 2011 | Tascam DP01 All-In-One Recording Package...
Toshiba 42hpx95 wont turn on.. when i unplug and plug in i can hear a sound but then a red light on the front starts blinking and it does nothing
the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Apr 29, 2010 | Toshiba 42HPX95 42 in. Plasma Television
Will not turn on looks like its on sleep mode
Solution is in my Tips & Tricks "Kitchen Table, Samsung - Won't turn on,...". Caps on the power supply need changed. I hope this was helpful.
Mar 30, 2010 | Samsung LN-T4665F 46 in. LCD Television
Turn table starts then stops
The gears inside under the panel are getting worn. IT may have to be taken in for repair unless you can order the gears from sharp and replace them yourself.
May 05, 2009 | Sharp R-930AK Convection/Microwave Oven
Volume light blinking, no sound.
Plug in some headphones as they are usually always active and see if you get any sound and volume control of them.
if not the switches may be stuck .
or the output fuses blown.
it gets sticky to work inside one of these without electronics experience and you can do more damage.
The fuses are about all you are allowed to fix.
Jan 05, 2008 | Yamaha RX-V992
Technics SL-1210 Turntable Logo
178 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
