Unlock Region Code for Philips 612 DVD Player
How do I find the code to unlock my Phillips 612 dvd player? It is currently in region 2.
  • rusky Jan 12, 2008
    Thanks for this. I did actually find this solution on the web, BUT:
    I don't seem to be able to find a OneForAll6 (URC 7560) - they all seem to be URC 7562 now, and I wasn't sure if that one would work. I also have been unable to find a SBC RU880 either.
    Is there a handset hack that will work?
  • 3 Answers
From http://www.dvddemystifiziert.de/codefree_en/philips.html
You need an OneForAll6 remote (URC 7560)
  1. Press DVD device button (set remote to DVD)
  2. Press and hold MAGIC until it flashes 2x
  3. Enter Setup Code (0539)
  4. Press MAGIC again
  5. Enter 085
  6. Enter 222 222 005 255
  7. (should be displayed)
  8. Press PLAY
for the remote "SBC RU880":
  1. Press and hold 1 and 6 until SYNTH is displayed.
karmor
Posted on Jan 12, 2008
  • Karmor
    Karmor Jan 12, 2008
    Rusky, the 7562 is set up in exactly the same way as the 7560 and uses exactly the same codes so you won't have any problems with it. The URC 7562 has a silver front, is a little bit lighter and has more advanced macro programming.
    karmor
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Unlock code for Philips DVD player dvp3650
Region code hack procedure for DVP3650 1. Power ON the DVD player with no disc inside 2. Go to the SETUP icon and press OK; next, go to Preferences and press OK 3. With preferences highlighted, 3a. Press NEXT CHAPTER (button above AUDIO, it looks like this: >
Sep 12, 2012 | Philips Televison & Video
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
DVD PLayer Region Unlock
hello mushkil
you could try the following
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all
regions
8. Press the "Play" button on the remote
this should unlock it to all regions .
riz.
Aug 16, 2008 | Televison & Video
Region 1 codes
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
Aug 11, 2008 | Televison & Video
Phillips dvp1013
Hello Canada416,
Check the following link to the regional code data base for codes you can enter through the handset to unlock region codes. Let me know if this helps you or you need further assistance.
Jun 30, 2008 | Philips DCP855/37 Portable DVD Player
Televison & Video Logo
329 people viewed this question
Top Televison & Video Experts
