Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover shampooer motor is running ,but no suction
  • 126 Answers
When you place the recovery tank on the machine, there is a mating of the tank to the motor intake and this directs the suction into the tank. Make sure the lid is on the tank correctly. You also should check that the seal on the motor intake is in place. Take the tank off the machine, and look on the front left area where the tank sits. There is a round intake and should have a black rubber seal sitting on top of it. Sometimes these seals fall off. If it is missing, check inside the machine around the intake and you may find it lying in there somewhere.
Posted on Jan 13, 2008
How to fix no suction?
Be sure the motor runs then unplug the unit and thoroughly check the suction side to be sure it is not plugged with some obstruction. Here are some links that may help:
Hoover UH71011 Product Manual
Sony service manual Samsung service manual Panasonic service manual and...
Mar 03, 2015 | Hoover Elite Rewind Bagless Upright...
My carpet shampooer will not **** the water back up. It is a Hoover Steamvac Deluxe 1600.
Check the filters, make sure they aren't clogged. Also if this has the foam filter on the inside of the tank lid, make sure it has at least a 1/4 is gap from the top.
Jun 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How do I take the top off my hoover spinvac shampooer
1) test the motor outside from the machine, carefully and do not touch any side live wire.
2( see the diagram simple for help and test the motor, otherwise you must go to the repair shop motor.
God bless you
Jun 18, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet shampooer is smoking and not working. Is the motor shot?
If it smells like an electrical fire, the motor will need replacement ( part # 43576197, msrp $74.99 ) + labor.
Jul 30, 2011 | Hoover F7431-900 SteamVac Vacuum
Hoover upright bagless vacum.motor runs, brush turns, no suction through hole behind brush roller. however there is suction going out of dust cannister filter flap to motor. what could possible problems...
Sorry to read about your problem, I hope this helps you out.
you have a clog between the brush and bag
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
The hoover shampooer will not extract the water from carpet, is it because the carpet is so low ?? the carpet is cleaning fine there is VERY poor underlay and then wood under that, worried about the wood...
do you have suction at the front of the base,if you don't then look at the plastic cover on the base,you should be able to see through the plastic.the suction slot on the bottom front of the base is very narrow.i don't know if you have pets but most of the time the suction chanel gets clogged with hair and dirt.the chanel is right up the middle on top of the base.look in there and see if you don't see a lot of hair and dirt stuck up inside.there are some screws on the bottom that you need to take out to remover the cover.then the cover comes apart in two pieces to allow you to get to the suction chanel.please leave some feedback.i hope i was some help to you
Apr 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How far down do i push the attatchment hose on the reconery tank it is very hard to push down on the hoover shampooer
you want the top of the attachment level with the top of the tank, this way it will create a seal so you have suction through the hose.
Sep 26, 2008 | Vacuums
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Jet and Wash 1500w S6254 001. Used once with great difficulty as assembly and use instructions are hard to follow.Now will not work as carpet shampooer at all, although assembly is correct as far as...
i am having the same prob my uncle got me one i cant find the manual anywhere to set it up the prob i have is where does the handle to make the water go out connect tooo ??? on the main pipe that sucks it back up i have tried every which way but not the right way obviously lol as for it not spraying mine did for all of 2 secs but think it was because i got a bit happy with the solution so gunna just try water and if its too hot it stops it spraying properly too !!
Mar 30, 2008 | Vacuums
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
41 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
