Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Washer trouble
By Rhedwynd on Jan 12, 2008
Hello
I have a HE front loader that is flashing the codes dL F and does not work.
Any suggestions?
Thanks
Comments:
Jan 12, 2008
- OK thanks for your help. That sounds difficult for someone not handy. The model # is 11042922203. It is a HE3t
Best Solution
posted on Jan 12, 2008
Very Helpful)
watugot
Rank: Guru
Rating: 94%, 388 votes
F DL is a code for door lock failure. Either the door latch is bad or the main control is not sensing the door latching and is giving the code. Many times it is a bad connection where the door latch wires connect to the main board.
Post back with any questions.
Thanks/mike
Comments:
Jan 12, 2008
- This is most common on the HE4's. If this is what you have, you can remove the top of the machine by removing the 3 screws at the back of the top. The top will slide back and up. The main control is mounted at the top rear of the machine. The door latch wires are the pink ones marked dl1 and dl2.
If you will post the complete model number from the machine I will try to walk you through the diagnosis and repair.
Thanks/Mike
Jan 12, 2008
- The actual repair is not to bad but you may need to check some voltages with a volt/ohm meter to figure out whether the problem is in the board or the latch. You also want to make sure the part of the latch attached to the door is not broken.
If you have a tech come fix it, replacing the board will be in the $400 range, replacing the latch will be $200-$250. The good news is that the older HE3's have very few board failures. If it is less than 2 yrs old you may still have warranty on the control boards. Check your owners manual.
If you don't have a meter to check it with, this is how I would diagnose it.
When you start the cycle you should hear a slight click coming from the back of the machine followed by a louder click at the door latch in the front. This will repeat a couple times as the board checks the latch. If you hear the quieter click at the back but not the louder click in the front, then usually I find the problem is in the control or the connections at the control. If you hear the loud click in the front but the board still gives the code, I usually find the door latch to be the problem.
If the door is locked and you need to get it open, remove the lower front panel from the front of the washer. There are 3 screws holding it. It will slide down and off. You can reach up to the bottom of the door latch and feel a plastic tab hanging from the latch. Pull this tab down and the door will unlock. There is also a tech sheet behind this panel with all the specs for checking the components.
If you want to try the repair yourself, post an email address and I will send you a repair manual in PDF.
Thanks/Mike
Rating Locked! (?) Rhedwynd has rated this solution as Very Helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
The diagnostic test showed u1; don't want to electricute myself testing the wires/switches.
Answer
Which compartment does softener go into.
Answer
I have maytage neptune model mah3000awa front loading wash machine and was told the drain pump may... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
