My heating element has white scale on it, I know it's from Cascade dishwasher soap. How can I remove it?
There is a product that they sell in the store called Dishwasher Magic. You put the container in the dishwasher and run it with no dishes in it. It will clean the inside of the dishwasher pretty well. You could also try running it empty with a cup of vinegar to help break up the scale build-up.
Hello, You should buy some lime away from home depot ot Lowe's. Put 2 cups inside the dishwasher and run a pots and pans cycle. This should clear up the calcium deposit on the heater. You may have to repeat depending on how bad the build up is. Hope this helps. Mike
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
I will try Lime away, unless anyone happens to know where I can buy a product called Glisten in Canada. I live in Edmonton, Alberta.
