Question about Medion md40298 Notebook
Medion mim2120 Hi I am having power input problems there is no lights come on when I connect the power adapter. The adapter light is ON so I think the power is getting to the machine. though it is not the origanal adapter. It is has an output of 19v as recomended for the machine. I have looked the input terminal on the mothboard and it looks clean and NO burn marks. Any help would be appritiated. Thanking you Brian
  • iain hosie Sep 15, 2008
    The light is coming on on the power adaptor, but the laptop(medion mim2120) is not turning on. I think it may be a problem with the cable going from the adaptor to the back of the laptop?
  • magic marty Oct 28, 2008
    light comes on the power adapter but no lights come on the notebook but im using the correct power pack
    Novelist:
  • 188 Answers
Have you actually tried another adapter already??
It sounds like something has burned out on your mainboard. However depending on the model it may have a removable power board. You may have to find someone that can trace down the power circuitry of the system with a meter.
You mentioned this is not the original adapter- There is definitely a chance that your adapter caused this problem. I never take a chance on a higher or lower amperage AC adapter with a laptop, since it stresses the power circuitry of the machine. Even if you can get it going again, i would strongly recommend getting a closer to spec adapter.
Posted on Jan 12, 2008
No power light nothing working
Hi Keith, i would suggest contacting Medion as this appears to be a faulty mainboard, but you could try checking the obvious (ac adapter fuse) and the ac adapter could be faulty, can you check on other equipment, if out of warranty then you may have to take to a good local tech.
Feb 01, 2014 | Medion Computers & Internet
Hi I have a medion akoya p6613 notebook pc The
You need to get the DC socket replaced, or the original one resoldered. Your power supply may be broken, but it is more likely that it is the socket. Check the cable on the power supply for any breaks or floppiness at the joints. (an indication of a broken core)
Sep 23, 2013 | Medion Computers & Internet
Red light flahes even when power adaptor is connented
Most likely this is due to a faulty battery. This indicates that the battery is unable to hold a charge despite being plugged in with the power adapter.
Feb 28, 2011 | Medion MIM2120 COMPATIBLE LAPTOP LCD...
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
How do I fit wireless card into medion mim2120 laptop?
I assume you mean "wi-fi" wireless access. The easy solution if wireless networking wasn't built in is to use a USB wireless adapter that simply plugs in to any USB connector on the laptop. These adaptors are available at retailers where you can buy computers as well as from many online sources. The adapter will come with any software and installation instructions you need.
Please take a moment to give this solution a fixya rating if it has been what you needed, and thanks for asking here!
Mar 05, 2009 | PIONEERPOS M55E25R30P PC Notebook
Medion mim2120 Wireless Problems
I had similar problem with Medion WIN 2140. The harddrive crashed, I bought a new drive and had to reinstall Windows from scratch since I had neither a backup or burned the reinstallation CD's. First I installed Windows7 and every driver/application/BIOS available from Medion's download site. At first my WIFI worked OK but somtime during the process og BIOS/driverupdate my WIFI antenna turned off. The antenna can be turned on/off with a easy access button (touchpad to the right of powerbutton) but WIFI button dows not work.
Medion's danish supporters told me that Windows7 is unsupported. So I had to reinstall using Vista. Still not able to turn on WIFI. I'm pretty sure that BIOS prior to version 1.0K (dated 06.01.2010) had a "ON" possibility but is now limited to "OFF" og "LAST STATE".
Medion support wouldn't og couldn't provide me a previous version of the BIOS. In fact Medion DK's support doesn't seem to know anything about their products.
However I have found the solution myself. Launch Manager application is needed for Easy Access buttons to work. Current version 1.5.0.5 of the application is faulty. In registry i found that pressed keys call the file fn.exe, this file is not a part of the OS, Launch Manager or any other Medion driver/application.
I googled for and found the prevoius version 1.4.9 of Launch Manager. This version works without any problems on both Vista and Windows7.
http://www1.medion.de/downloads/?op=search&lang=au&type=TEXT&Param=
I wrote to Medion support to replace the faulty application on their support site. But with my current Medion experience i daught they will do anything about it. So instead I post this reply to help others.
Oct 15, 2008 | Computers & Internet
Laptop keyboard not working medion mim2120 notebook pc
this and my mouse have also stopped working, idk the problem but i fixed it once and whenever i wanted to turn it off i just put it into sleep and it worked fine when i started it up. i came to a situation where i had to restart the computer and it didnt work again and now i cant fix it.
Aug 18, 2008 | Computers & Internet
Recovery of xp
The safemode may not be accessable probably because you have the Other Gadgets connected to the comp.
Turn Comp off...
Remove every thing(except Keyboard,mouse,monitor& power.)
Then Keep Tapping F8 to enter "advanced screen options menu".
***If the safemode would not enter then enter the safemode with command Prompt.
***Log on to your computer with an administrator account or with an account that has administrator credentials.
*** Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
if all this do not work and the OS is an OEM then the manufacturer of this computer should have a to Recovery the OS by formatting the comuter.
Jul 18, 2008 | Medion Computers & Internet
Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Feb 23, 2008 | HP Pavilion dv6000z Notebook
Medion MIM2120 laptop
press the blue button botton left of the keyboard that says Fn (function)
at the same time press F1 this will enable the laptops wireless connection, this should be shown by the light 2nd from the right
Dec 04, 2007 | Medion md40298 Notebook
Medion md40298 Notebook Logo
169 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
