Question about Sony Playstation 3 (PS3) Console
Ps3 power hey i have a ps3 8-gb and live in england i am hearing a funny noise when i turn it on is this because the convertor plug is not working correctly. i bopught it on vacation and it work fine over there in the usa what should i do try a differant adapter or purchase something differnat
    Scholar:
  • 64 Answers
Try and find a better/different adapter, maybe one the is specific for the PS3 or gaming in general. Don't use one of those universal ones, could fry your PS3.
Not sure what kind of outlet/plugs you guys have out there (I'm in Canada, eh) but I've provided a couple of links that should help you out. Personally, NYKO is a great choice, quality stuff and they have lots of accessories for the PS3.
http://discoazul.co.uk/powercord-nyko-ps3-european-plug-adapter/product_info.php/products_id/3206
Due to the volt difference; Europe (220v) vs. Canada & US (110v)
you MIGHT also need a power converter. Check the console, it will probably be able to handle 110v-220v but double check to be sure. I have heard all kinds of answers and opinions about it but best to check your PS3 yourself. If it odesn't support both voltages then you will also need to get a power converter.
Posted on Jan 13, 2008
Keurig K75 Convertor for England
Try this link:
www.amazon.com/International-Voltage-Converter-appliances-overseas/dp/B000WQ0MTG/ref=pd_sim_hi_4
This one should work fine for the coffeemakrr. Hope this helps.
Dec 31, 2013 | Keurig K75 Platinum Brewing System with...
My ps3 picture dont come on
are all your leads plugged in right? and also what colour is the light green or yellow?
Aug 05, 2012 | Sony Playstation 3 (PS3) Console
I have a 1989 Mercury Grand Marquis LS with a 5.0 V-8 FI Engine with aprox 174,000 miles. I drive this everyday, but about a month ago, it started to run funny. It feels like it's missing out. I have...
the only real way to confirm this is to have the fuel pressure checked out using a fuel pressure gage.it could also be a convertor plugging up in which case you can check the exhaust backpressure tested to see if it is.another way is to hit the convertor to see if you hear a rattle inside,if so the convertor material is breaking up and causing the exhaust to be plugged.some of the material could have travelled down the exhaust and is causing a problem.
Sep 15, 2011 | 1989 Mercury Grand Marquis
4 fans bought in April from Costco and pac tested. 1 makes a a funny sound when plugged and does not work.. Can this be brought to a centre to be repaired as a callout cost 55 pounds Many thanks Mrs...
It sounds like you bought these items online from Costco, unless you have a Costco close by. Using the term "pounds" tells me you are in England someplace. A repair shop should be able to repair the problem easily and quickly. The noise you hear might be from the motor that is trying to start. Did you try a different power supply to see if the problem is your power outlet? You might try that. Cheers.
Jul 16, 2011 | Honeywell Dryers
Why isn't my ps3 not working. I plugged it into my HDTV in my living room, then plugged it into my normal TV and now it's not working?
You need to reset the A/V out settings.
Have your PS3 in standby mode (solid red light). Press and hold the power button, you will hear one beep (power on), then you will hear another beep (reset). Release the button at this point and the video should reset and work on your standard TV using the red/white/yellow RCA cord.
Thank you!
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
We tried to play a region 2 game given to us in England over Christmas. As soon as the game was put in by my nine yr old he answered a question which no one else saw, answering no. Immediately after, the...
Try to RESTORE FILE SYSTEM.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
Error code 80010514 been playing modern warfare all day and now it has threw up this error code and is not letting me play i have tried restoring file settings but nothing i just had a new laser fitted 2...
You need to RESTORE FILE SYSTEM to correct that.
Follow this guide.
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont read discs.................
Try to restore file system on your ps3.
Follow this guide.
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
My controller connection to my PS3 constantly dies after about 45 minutes whether its plugged into the USB port or not. How do I fix this?
hey i had my ps3 for about 8 months or so i got the message i did everything unplugged it didnt work held power button 10 seconds restarted it nothin- mine makes a weird noise and the orange light saying its loading wont turn off if it does that it pretty much means A. your hard drive is fried B. your hard drive isnt responding with system C. you turned off your ps3 while loading something and it fried it i think is what happened to me
Dec 11, 2008 | Sony Playstation 3 (PS3) Console
American PS3 in South Africa
Hey thomas952,
While they may not be region-coded, PS3 consoles and games sold within the United States are going to be NSTC compliant, instead of the PAL format used in the United Kingdom and South Africa. What this means is that in order for any game to display properly (or even operate) it must be purchased from the same region of the world as the console itself - NTSC games can only be played on NTSC consoles.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
