Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi 50605 I cannot get the tv to turn on, it will ccom on for a sec, but that is all it just shuts right back off. and i tried the hair dryer thing for coolant leaking and i did the daignostic and the code is 2-3. can u help me or do i have a piece of junk? Sara
  • Mitsubishi Master
  • 8,617 Answers
Code 23 means horizontal deflection failure. Check your horizontal output transistor. Or the horizontal drive transformer solder joints as well as the horizontal yoke pin connections for bad sloder.Hope this helps. if I can be of further assistance let me know
Posted on Jan 12, 2008
6ya staff
SOURCE:
I have a mitsubishi vs-50605 and when i turn it on the light comes on and clicks and the instantly clicks and shuts back off, I pushed the menu input buttons for five seconds and got one blink then two...
1,2 is no error detected---if during or before this you unplugged the set that clears the errors and you will get 1,2.
To confirm with set plugged in turn it on--when power light goes out repeat the self check.
May 15, 2012 | Mitsubishi VS-50605 50" Rear Projection...
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
No picture . tvturns, immediately turns off
Your TV set is in protect mode .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted.
Good luck;
Regards:
VOTIT
Jul 01, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi Convergence Problem
you need to replace the convergence board but it will cost you around $200 to fix the board and components associated with it .......
Have you tried adjusting the convergence settings ........
Power up on tv
Usually, that symptom indicates CRT coolant leakage on the
circuit board below the drip.....creates a short circuit,which
turns off set.....Have it examined by a Mits tech to be sure......T.
Dec 04, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Tv wont turn on only clicks and then flashes red timer light
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Nov 20, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a 50 vs5051
1)Inspect circuit boards for CRT coolant leak! Wet evidence usually on signal board. 2)Possible bad regulator or bad solder connect, esp.regulator output pins. 3)Next? Diagnosis by qualified tech.
Oct 09, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
