Question about Sony KV-32V26 32" TV
Sony trinitron TV
No picture, picture comes initially for a second and later screen moves up on the screen with horizontal lines, and screen becomes complete dark. though sound is perfect
  • ashay Jan 13, 2008
    thanks billy:
    you saved our TV going to junkyard, though do you know actual value R530 resistor
  • 42 Answers
I have seen this problem before.
The problem turned out to be caused by a poor solder joint on R530. This is in the HV
sensing circuit and is associated with IC501/ comparator. The resistor was replaced for
good measure and proper operation restored.
Posted on Jan 12, 2008
  • billy jones
    billy jones Jan 13, 2008
    It is a metal glaze resistor 1/10w 22k
    If you need the full manual for this unit, email me at:
Have lines up and down screen
If your lines are vertical, you have horizontal problem. Vertical lines are a result of an aging TV. It would not be feasible to repair this. There has been an overworked Flyback transformer, Horizontal transistor and regulator and an aging picture tube. It is time to find another TV.
Sep 27, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, has sound
This problem usually lies on the horizontal output transistor, try to check also for shorted diode. you can buy ftom any electronic parts dealer or radio shacks stores
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
DVI port on Sony Trinitron KV-32HS500 not standard.What fits it?
I've just recently connected my old 32" Sony KV-32HS510 to my HP G60 Laptop via an HDMI (laptop) to DVI HDTV port(TV) with a cable.
I'm running Windows Vista on my laptop with the nVidia software. Once I've plugged in the TV to the HDMI port, the software initializes (recognizes the TV) and then I can select it as my second 'monitor' in the nVidia control panel.
I found I had to tinker with the resolution settings in the nVidia program to find an optimal resolution where the sides of the screen weren't 'cut off' by the TV.. I finally ended up with the resolution 1152x768 (I believe). It might be different for everybody, as I'm told Vista might do things differently than XP... But you should be able to tinker with the resolution settings and adjust the screen size...
(hope this helps with the second post - above)
Feb 11, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
TV goes black at bottom and has horizonal lines in middle?
Hello, please check the high current area around flyback transformer, horizontal output transistor as well as the deflection connector for bad soldering. Best regards, Arpi If you need more info please advice.
Apr 12, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
32" Trinitron warms up picture goes black
You need to call for service now that the unit still turns on,the problem will become expensive if you try to use it like this,right now the set might have loose conections in the power supply,horizontal driver transformer.ETC.Be safe and call a service tech.
Sep 25, 2006 | RCA P46924 46" Rear Projection Television
Tv picture blinks off and on
The on and off conditions is repairable and is not the tube,you should have it check out for loose conections and try not to use it or it will go bad for good and the repair will become expensive,Check power supply,horizontal driver transformer and crt board,If you are not familiar with tv service be safe and call for help.
Sep 24, 2006 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sound but no picture
I believe the cable guy is correct and I will suggest you call for professional help now,if you try to use it like this the problem might become expensive.
Sep 23, 2006 | Sony KV-35S66 35" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
215 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
