Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Dishwasher--water in bottom -end of cycle.
Happened with old dishwasher & new. Hose not clogged.
  • Anonymous Apr 22, 2008
    drain cycle not starting, water left in bottom of tub.....
  • fireftr May 22, 2008
    Water sits in bottom of tub after dishes are cleaned. Manually turned timer knob, but no drain function.
You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. once drained put it through another cycle. this should reset the drainage level. hope this works as it has for ours, bye
Posted on May 23, 2008
  • Anonymous Sep 07, 2008
    However in saying this if it is a brand new diswasher it could be a fauty drainage valve if the other answer doesnt work then it should be under warrenty and they will shange it for free. it is not a very big job at all.
6ya staff
SOURCE:
I have a Bosch SHE4AM15UC dishwasher. It's been working fine, but yesterday I noticed that there was water in the bottom of the dishwasher after the cycle was finished.
Check the "P trap" where the drain hose connects under the sink. It may be partially blocked allowing water to syphon back into the machine or preventing it from pumping properly after the second or third pump out.
Nov 19, 2016 | Bosch Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
My GSD4020Z07BB dishwasher isn't draining out the water at the end of the cycle. This problem started all of a sudden as the unit was working properly before.
Check the drain located in the bottom of the dishwasher by removing the tray. It may be a clog. If there is no clog you can remove the drain hose from under the sink, get a bucket hold the hose in the bucket and try to drain it into the bucket. If it drains in the bucket the clog is in the sink drain, if not it can be a clog in the hose. If none of that works it could be the pump on the dishwasher. Good luck.
Jan 07, 2011 | GE 24 in. GSD4020Z Built-in Dishwasher
Hello the bottom of my dishwasher keeps filling up with water. How can i fix that??
The problem may be in one of several places, here's a list of things to try, starting with the easiest and progressing to more difficult:
1. Run your hand around the bottom of the pool in the dishwasher looking for paper or cellophane that may be covering the screen of the drain. 2. Disconnect the drain hose from under the sink (get a bucket and rags) looking for a clog at that point of connection. Run the dishwasher drain cycle while you have this hose pointed into a bucket - if nothing comes out, the problem is between points 1 and 2. 3. Partially remove the dishwasher so you can get to the drain hose where it connects to the dishwasher. Temporarily put another drain hose on it, with the other end in a bucket. Run the drain cycle of the dishwasher. If it comes gushing out, the drain hose is clogged. If it still won't drain, your will need some disassembly of the drain & pump. good luck, Al K
Dec 21, 2010 | Mx Commercial Line Drano Max Clog Remover
Dishwasher holds water at bottom after wash is done and cycle ends
Some water at the bottom of your dishwasher is ok. However if the water more than covers the bottom then you have a problem.
  1. First thing to try and this may fix the whole issue. Check the air-gap to see if their is a clog in the line.
  2. If your hose is clear change out your drain line and drain pump parts #99002750 and #99002652
That will fix it for sure. Have a great day!
Dec 07, 2010 | Maytag MDB9600A Jetclean II Built-in...
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Feb 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
153 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
