Question about Pensare' Rocket V17201 Handheld Vacuum
Pensare Vaccum Hi: I have an older Pensare hand held vacuum. It's the T-Rex, mod # 1505. My daughter lost the filter with the plastic frame around it that goes inside. I love the vacuum, it works great, so I don't want to buy another one and add to the land fills. Can I buy a replacement filter for it? Thanks! Autumn Moore 503-481 1817
  • clo636 Apr 09, 2008
    I also have a Pensare T Rex hand held vacuum and have been unsuccessful finding a replacement filter for it.
    I tried numerous other filters meant for different machines and none of them worked with it.
    For years now I've been cleaning out the filter and washing it but a new one would no doubt increase the suction power of this useful little machine.
    Any ideas out there?????
    Thanks-
    C
  • Anonymous Apr 04, 2009
    There is a notice in the box that directs you to T-rex, 199 Cherry Hill Lane, Parsippany, NJ 07054 for replacement filters. However, I have never been able to locate a phone number to confirm whether that address is still valid. 199 Cherry Hill Road seems to be an industrial complex with many manufacturers.
Dyson hand held vacuum runs for a few seconds then shuts off?
Hi, it's Allie from Crucial Vacuum.
Other than the battery being defective, this problem may be caused by a blockage or a dirty filter. If after checking your unit for blockages it still having the same issue, you may need to wash your filter.
Ideally, washable filters should be washed after every 3-4 uses. First, remove the dust from your washable filter. As it may spread around the air, it is best to do this outside. Tap the filter gently to get rid of most of the dust. With lukewarm running water, rinse the outside surface of the filter, without using any soap. Allow the filter to air dry between 24 to 48 hours before you replace it in your vacuum. Once the filter is clean and dry, place it back into your unit and turn it on.
To minimize the waiting time for the filter to be completely dry for it to be used again, it is highly recommended to have a spare filter to use while you clean the one in your hand held vacuum.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/vacuum-filters/dyson/dyson-dc30-dc31-dc34-dc35-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 14, 2014 | Dyson Vacuums
Aquamark hand held mod.am680 not steaming why
hi there did you find a solution i have the same problem thanks
Mar 01, 2013 | McCulloch MC1246 Handheld Steam Cleaner
How can I replace the rechargeable battery?
Hi There,
Officially Electrolux don't want to sell the batteries so they discount the price of the hand held unit. Here in Australia they are called ergo rapido but it will be the smae everywhere I would assume. They will sell the battery on its own but it is more expensive than replacing the hand held part (without the filters) .
Jun 12, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
I bought it in may , I can honestly say , it is THE worst vaccum
There are several filters on bag-less vacuums that need to be cleaned. Dig out your owners manual or open the one below. See section 3 for filters and maintenance. If you are vacuuming a house bigger than about 1500 square feet, you should be cleaning the filters every other use. Personally, after using a bagless for a couple of months, I went back to my bagged vacuum.
http://www.hoover.com/pdfs/manuals/U6630900.pdf
Dec 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dyson all floor vaccum no suction when hand held wand is turned on... doubled checked for cracks in hose -- none took house off unit to check for blockage --- none.. suction works fine when using as normal...
You need to replace the belt that drives the brush on the underneath side of the vacuum. To do this, you need to flip the vacuum over and remove cover plate. There you will find the broken, or stretched out belt. Remove the brush and place the new belt on the chrome axle. Then put the brush on, rapping the new belt around the brush as you put the brush back in place.
Jim
Jun 09, 2009 | Dyson DC14 All floors Bagless Upright...
NEED CHARGER MOD:HHD20-200
I have same problem. Please post it if you find source of battery charger HHD-20-200.
Apr 18, 2009 | Vacuums
Bissel Vaccum giving a foul odour
Hi - here are a few tips!
If the filters are washable they have to be dried completely before putting back into the machine, otherwise you're damaging your vacuum by putting in damp filters which won't do much but put back the stale smell into the home. Generally washing filters should be done with a little washing up liquid, washed out, rinsed, drip dry and dried over 24 hours to room temperature naturally (not on a radiator or heater).
Faster drying should employ the use of a low temperature tumble dryer with the filters placed in a pillow case with a towel added to prevent banging off the sides of the electric dryer when in operation.
Also, whilst the filters are drying take off the main hose of the Clearview and wash it out with washing powder with the hose laid in the bath. Alternatively put wet wipes or cleaning wet wipes down the hose with a stick to get out all matter of dirt - clearview hoses are the worst for stinking especially if you have pets. That should improve the general way of your vacuum and giving it a more neutral smell. Also when everything is dried out inclduing the hose, sprinkle some bicarbonate of soda around so that the vacuum picks it up and neutralises previous odours that the vacuum had from the beater bar/floor head.
Mar 28, 2009 | Bissell 3576 CleanView II Bagless Upright...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Pensare' Rocket V17201 Handheld Vacuum Logo
212 people viewed this question
Top Pensare' Vacuums Experts
Marvin
Marvin
Are you a Pensare' Vacuum Expert? Answer questions, earn points and help others
