Question about ASUS P5N32-E SLI PLUS (0610839148967) Motherboard
Computer does not boot up
I opened Nvidia Control Panel and noticed the setting was for a single video card. I have two cards installed, so I selected SLI and hit APPLY. The screen went blank and the computer turned OFF. Now the computer doesn't boot up. Any sugestions?
Motherboard: Asus P5N32-E PLUS
Processor: Intel Core 2 duo E6600 @ 2400 MHz
Physical Memory: (2x1024 DDR2-SDRAM)
Video Cards: GeForce7600 GS
    President:
  • 2,351 Answers
Remove the second card. There is a few other things that must be done before you can select SLI & run.
Go to page 4-26 of your manual. You must set primary display adapter to PCI-E within the bios
Page 4.24 section: 4.4.4 set to AUTO. Section 4.4.5 set to High Preformance. Make sure your connecting your PCIE card in the 2 blue x16 slots & not the white x8 PCIE slot, found on page 2-20.
Happy computing & please vote.
Posted on Jan 13, 2008
How to fix display driver not responding?
assuming you have the latest driver available installed with this graphics card, and without knowing which version of windows you have..
go to your Nvidia Control Panel (Rt click on the desktop)
go to the 'Set PhysX Configuration'
in the Select a PhysX processor drop down box.
change it from Auto select to the Graphics card.
should work. if not. roll back your Graphics driver to a previous version
Jan 30, 2013 | Nvidia GeForce FX 5500 Video Card Graphic...
I have Nvidia GeForce FX550 graphics card. I'm getting a double image in my text. So bad I can't read a string of numbers because they overlap. Is there a quick fix?
Check your settings to make sure you don't have some kind of 3D (glasses required) effect turned on. This kind of sounds like a symptom that you are describing.
Alternately, you can try on a pair of 3D glasses if you happen to have one, or start the computer in safe mode (tap the F8 key right after start-up and select safe mode. You should not notice any doubling because the graphics drivers are not being loaded.
If none of these ideas work, I would suggest reinstalling the drivers. First, uninstall the current drivers (control panel/add or remove programs, and select uninstall drivers. Then get the latest ones from nvidia.com. and then install them. Reboot if needed and try again.
Jan 29, 2012 | Nvidia GeForce FX 5500 Video Card Graphic...
Hi,i bought an aoc 2243fw2k monitor with dual hdmi ports,n i hav an nvidia geforce 220gt 1gb ddr3,i instaled the drivers n graphic card drivers n kept all the conectins properly,bt i wont get the video in...
http://www.nvidia.com/object/win7-winvista-32bit-285.62-whql-driver.html
this is teh driver you need (windows 7 ) If you need it for windows xp ..you have to select the os first .
Also if you need it for a 64 system select it ..and install it after download.
Use the hdmi for to have a hd image ..and select the correct port in the monitor ..
restart after finish the driver installation .and make the settings
after..Also check the board in device manager to be proper installed (right click on computer icon ..select properties than device manager (for xp select first hardware ) ..and in helist look under display ..and the driver should be present by name and not with yellow color and exclamation or ask sign ..
Also it may need some settings in the video card ..so open the settings for video card in control panel and look up for what should be set ..specially related with the secondary monitor and the hd mode..
Dec 15, 2011 | Computers & Internet
Trying to get 2 monitors working
plug your LG display into the DVI port and the BENQ into the VGA? it may just be a random compatability error.
May 04, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
Cant seem to install new graphics card
First uninstall graphic driver from computer.
For that when you power up the computer press F8 key then enter in safe mode.
Then go to device manager.
For get device manager right click on my computer iocn then click on property then hardware->device manager.
Then you can see all driver list uninstall display adapter graphic driver.
Also go to start->control panel->add remove program then select nvidia graphic driver and uninstall it.
Then restart computer.
then download exact driver for your model from below link.Then install in computer.
click here
Click on above link and select your model then download driver for your operating system then install.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 09, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
2nd monitor doesnt work either
Ensure your are running the monitors in dual mode still. Open your Nvidia Control Panel and click on "setup up multiple displays" Then on right panel you should see where to select your option on how to run the 2nd one. You might need a driver update from Nvidia, especially if you recently took an update from Microsoft.
Hope this helps
ps Here is the link to Nvidia: Click Me
Sep 26, 2009 | Pine Technology XFX GeForce 7950GT, (512...
Setting up dual monitors with NVIDIA 7300 GS Graphics Adapter
so...
your computer don't recognize your nvidia graphic card in PCI Express slot.
you are runing now with computer's integrated graphic card?
if so then you won't have dualview option. in this case it looks for me like you've installed in the wrong way your graphic card.
your NV GeForce 7300 GS has 2 video output?
if yes then you should have the option for 2 monitors on nVIDIA control panel (i have check my nVIDIA GeForce 7600gt and in my case this option is present but is enabled only if i connect the second monitor, so try do so)
you have installed the latest nVIDIA drivers from the official website? http://www.nvidia.com/Download/index.aspx?lang=en-us
check if your video card is corect installed start/run type in " devmgmt.msc ". it will open device manager and under the display adapter tab you should see what video card you use now.
Feb 23, 2009 | HP Pavilion a1700n PC Desktop
Com to tv
do you have the card set up to use the s-video cord?nvidia control panel will help you do this.
also make sure your tv source is set to s-video input selection.
Jan 28, 2009 | Nvidia GeForce4 MX 440, (64 MB) Graphic...
ASUS P5N32-E SLI PLUS (0610839148967) Motherboard Logo
122 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
