Question about Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW)
P660HW I have installed the above router but when I'm connected to the internet via ethernet and a wireless internet connection is set up it cut's off my desktop connection
  • 1 more comment
  • Anonymous Jan 23, 2008
    i have exactly the same problem i have been doin everything i can but if i connect the grey wire then i have internet on the laptop but if i connect the black on tht comes with my dial up i have internet on my desk top plzz zhelp driving me crazy
  • LondonHans Mar 04, 2008
    Yes - same: desktop gets knocked off Internet connection when another device (laptop or smartphone) logs onto the wi-fi router. Tried quiet a lot of things including, sadly, using the Netword Wizard on the desktop XP whose settings I would happily delete but cannot.
    But, now very happy at finding MalfoyKaine's suggestion. Which works for me. 10 out of 10 and have book marked this site for life. Spot on.
  • networkmagic May 11, 2010
    Can you determine what firmware version your router is using? The user manual (on disc?) should have information about finding the current firmware version.
    Problem Solver:
  • 5 Answers
This has nothing to do with firmware!
You need to login to the router (http://192.168.1.1) and select the advanced setup, on the left hand side of the screen you will see some words written in blue (network, maintenance, security etc) select the "advanced" one and then "bandwidth mgmt" there are 3 lines here (LAN, WLAN and WAN). Untick all the "Active" boxes and click "apply".
Logout and reboot both your computers........problem solved!
Posted on Jan 14, 2008
I have a toshiba satellite laptop my router is a zyxel p660hw the laptop can connect wirelessly to the router and gets full network access but no internet connectivity i work in an office and there are...
what is the laptop's ip address when on wireless ? default gateway ? subnet mask ? when connected on wireless ?
what are these when connected to cat5 ethernet cable ?
Is the default gateway different ?
is the ip address within the network address ? 10.0.0.3 to 10.0.0.254 or 192.168.1.3 to 192.168.1.254 ?
the first three digits should the same
what is the wireless ip address is it the same as the network router or different ?
What is the dhcp leases are they conflicting with the main router and wi fi router ?
How many DHCP servers are there ?
Nov 16, 2017 | Zyxel Prestige 660HW Wireless Router...
I have a Zyxel P660HW-T1 v2 and when trying to use laptop wirelessly, the internet connection keeps dropping. While connected to the router by ethernet cable, internet is fine. All was working fine until...
For that you need to change wireless channel type in router. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless->wireless channel type to 3 or 6 or 11 then save settings and restart router. . Let me know if you need further assistance. Thanks for using FixYa.
Jun 22, 2011 | Zyxel Prestige 660HW Wireless Router...
How do i make the security settings?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jan 02, 2010 | Zyxel P660HW-D1 Router
Can't connect my Ipod touch to my router?
i had the same problem too with my'n. My issue was on of my setting's was set to block that wi-fi connection. Try switching your setting for finding internet connection from automatic to manual. that should do the trick!
Dec 20, 2008 | Zyxel P660HW-D1 Router
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
ZyXEL P660HW-61
while your computer is directly connected to the router, try to change the channel to 1,6 or 11. Try to enable wireless security and disable firewall on your computer. try to turn off other wireless device that may cause interference on your network
May 08, 2008 | Zyxel P660HW-D1 Router
No access to internet via wireless or ethernet
Check ADSL is active and connectted on the router.
Use webmanagement link the link below.
http://192.168.0.1
username: admin
password: admin
If the above details does not allow you to connect, check under the router for correct details.
Mar 11, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Zyxel P660HW with vista issues
If you are connecting via usb you will need to install all software and drivers on your pc before plugging modem in. If you did install them already you may need to reinstall
If you connect through ethernet (RJ45 terminated network cable), you may have a firewall preventing regular acess to network.
solutions
1) restart pc and modem it may work just with this
2)USB only: reinstall all modem software, then restart all.
3)Ethernet only (network cable), |Restart all and disable firewall. If this does not work you may need to change network settings on your computer (fo example change IP from static to dynamic).
regards
Feb 24, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW) Logo
176 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
