Question about HP OfficeJet G85 All-In-One InkJet Printer
Turn unit on/off button does not work
The button to turn the printer on is not working. How to fix it?
  • Jocelyne Jan 16, 2008
    Thank you for your suggestion about unplugging and plugging the printer back.
    It did not work....
    How to get someone to come and fix it?
    How much would it cost?
    Thank you
    Jocelyne
    hcsrv@yahoo.com
  • xhel Feb 15, 2008
    The power display didn't turn on, the lamp on the cable is on.
    What can I do ?
    President:
  • 4,402 Answers
First try unplug and plug it back in
Posted on Jan 15, 2008
  • Cary Farah
    Cary Farah Jan 16, 2008
    go to hp.com and select support
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
My hp 6300 front panel lights are not working...how do i fix
Try below resets, one after the other if issue persits.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
May 30, 2011 | HP Officejet 6310 All-In-One InkJet...
Error Code 6C10, what does it mean?
It's probably a waste absorber issue.
A fix from FixYa Support:
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
Get more help from here .Hope this helps.
Sep 14, 2010 | Canon Office Equipment & Supplies
I have a Cannon MP 620 all in one printer.When I go to print I get a error message 6C10 what is itand how do I fix it
http://www.fixya.com/support/t5998845-error_code_6c10_mean
Hope this helps.
Aug 01, 2010 | Canon PIXMA MP620 All-In-One InkJet...
The waste ink asborer is full
first you try with reseting if it is not works then you need to replce just follow this,
Just follow these steps to fix this,
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
My canon ip2000 won't reset
Canon IP 2000 / reset Hi there you can try this.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the Best Pineworks
Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
Ip5000 - Ink Absorber full
turn-off the printer
next hold steady the on-button of the printer and switch on
release the on button
press the on button
happy printing
Feb 16, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
WASTE INK NEAR FULL
I have the same problem and my power will not turn on if the resume button is depressed. Is there a way to fix the waste ink problem?
Feb 06, 2008 | Canon MultiPASS F60 All-In-One InkJet...
LP 2824
Here's the right way to fix the problem.
Autosense Procedure, Configuration Label and Dump Mode:
Models: Orion (2442, 2443 and 2543), Transport (P-2242), Xport (P-2222), LP/TLP Strata (2684), LP/TLP-2722, 2742, 3742, LP/TLP-2824 ,LP/TLP 2844 and TLP-3842
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the "Out of Dump" message on it.
Printer is now ready for use.
Oct 10, 2007 | Zebra Eltron LP 2824 Thermal Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
