Question about Logitech Z-5300 Computer Speakers
Speakers All Cut out Including Sub When Music is Played Loud
When I play my music loud with the bass up a bit all my speakers including the sub cut out for about 10-15 seconds and then it comes back again. This will keep happening over and over again. I've noticed that if I turn the volume down all the way and then turn it back up it's like it resets it and the sound comes back on. This is my second Logitech speaker system. My 4.1 had even heavier bass and to be honest I think I liked it better than this system. What happened with that system is the sub coil I think melted. Now, I wish these systems were built with a little better quality. I'm not always cranking it but every now and then, yeah, I like to crank it up a little. Is it too much to ask for a speaker system that won't cut out or blow a sub when these speakers are supposed to be rated for higher amps? Now as far as my Z-5300 system, I'm not sure if maybe this is cutting out as a safety but I wouldn't think it should be doing that after just a short time of playing loud music. Any help would be much appreciated. Thanks in Advance.
  • Anonymous Feb 19, 2008
    I have the same problem, works fine if its down low. But who wants to have big speakers when you cant turn them up. I can only turn them up to about 2/5 of the way! help plz
    Same problem help!
If anyone could email me on why my speakers just cut off and wont come backk o i would appreciate it.
hodajesse@gmail.com
Posted on May 14, 2010
Hey there i have the same problem but the thing is these speakers are cheap speakers i am on my second 5300 system because the first one sub woofer coil shifted for some reason and well all the satellites blew...the speakers are china based stuff and the amp over heats a lot...so u gotta set it down a bit or throw it out the window....lol...........smeeegle_tt@hotmail.com
Posted on May 17, 2008
  • 3 Answers
UNPLUG THE GREEN WIRE FROM THE COMPUTER AND PLUG IT INTO A CD PLAYER IF IT WORKS BETTER ON A CD PLAYER THAN THE COMPUTER IT SELF THERE MAYBE A PROBLEM WITH THE SOUND CARD AND ALSO TRY THESE STEPS I AM GOING TO GIVE YOU I AM SURE ONE OF THEM WILL WORK.
1. Please ensure that the all the connections between the satellite speakers and the subwoofer are firmly connected.
2. Next, please connect the green colored 3.5mm audio jack to another audio device such as an iPod or an MP3 player.
3. Ensure that the SoundTouch remote control is firmly connected to the back of the subwoofer.
4. Connect the power cord from the subwoofer and connect it to another single power outlet in your house. If you have an automated voltage regulator (AVR), please connect the power cord through the AVR instead of connecting it directly to a power outlet in your house.
5. Power up the speaker system and check whether the power button on the SoundTouch remote control will light up.
6. Turn on the Matrix Mode ON. This option is on the SoundTouch remote control. This is to ensure all speakers from the speaker system will produce audio that will be played from the audio device.
7. Play audio from the audio device. Check and see whether the all the speakers will produce audio being played from the audio device.
IF NONE WORK TRY THESE STEPS:
Posted on Mar 27, 2008
I have the infinity rs8a tower speakers and they sound good but when I turn the volume up the subs turn on and off on both towers
When sub-woofers are overdriven (played too loud) they create a lot of heat. You can try using an external fan or improve the ventilation around the speakers. Most good speakers have thermal cut offs that prevent permanent damage.
Mar 17, 2014 | Audio Players & Recorders
12 inch sub(JBL) in box with a 500 watt pioneer amp, sounds good with some types of base. would you cut a port hole in speaker box?
riverray1969 it would help if I knew the exact model number of that JBL sub you are referring to. With that info I can provide exact specs.
Basically, you need to build/modify an sub enclosure that is suited for the sub, the music you mainly play, and vehicle tuning. Generally, sealed enclosures will provide tighter bass response and get decently loud. Some would argue that it will give you greater sound quality. A ported enclosure will give you a louder more booming sound. That depends also on where the port is tuned (ex. 32 hz, 36 hz, etc ). You need to make sure that the enclosure meets the sub's airspace requirement as well. A customized well made enclosure is just as important as the sub you put in it.
Oct 16, 2012 | JBL P-1020D Car Subwoofer
Hi! I have purchased a JAMO S608 HCS 3 and a SUB 650 using an OKYO TX-SR508 Receiver. I can't set it up correctly. When I played music I've heard a lot of bass, I think there are some high...
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
Sep 08, 2011 | Jamo SUB-650 Subwoofer
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
Hello. My mirage sub just started to make a fuzzy noise when playing the bass...it happened after a party that played music on the sub very loud. I don't know what to do....help!
You have damaged the sub by playing it too loud.
Its either the map or speaker that has gone.
You should send it off to get repaired.
Please dont forget to vote this answer was helpful
Many thanks
Feb 20, 2011 | Mirage OMNI S8 Speaker
When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Audio Players & Recorders
AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
No sound
check the plug that goes directly to the altec box. or it could be the wire is the culprit..
Apr 08, 2008 | Altec Lansing VS4121 Computer Speakers
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
Logitech Z-5300 Computer Speakers Logo
1,006 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
