You will need to remove the cable operator assembly first. Under the sink, unscrew (turn it counterclockwise) the operator with your hand. Then remove the butterly-shaped retainer and use a needle nose pliers to remove the cam assembly...don't get too rough. Pay attention to which way they both fit.
Once the cam is removed, you can remove the pop-up stopper and proceed as required to clean the drain. Re-assemble in reverse order. Do not overtighten the cable operator.
Most bathroom sinks have a screen in them or a plug so u cant go directly from drain you will have to get underneath it and take off the trap it is were the pipe does a u shape. take it off then clean the pipes out with the snake oh when you take off the trap you will need a bucket or bowl there will be water oh and in that trap there will be lots of gunks just dump in the bowl/bucket then throw out side when down dont pour back into drain
