Question about Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive
Help compaq ex2200 wont turn on
This has a led screen that says press start...so when i press start nothing happens...when i unplug the power the led goes out..so i know its getting power...i removed the battery and tried a different one..still nothing....what now
  • freebiefan Feb 11, 2008
    i have xp and it ran one day then one day it just up and quit...i thought it might be an issue with the power button???
    Sergeant:
  • 390 Answers
You obviously have power, as lights and at least some text means power is connected ok, as you said. It may be a booting issue then. What OS is running on it when it did run???
Posted on Feb 11, 2008
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Power switch
check your connections..chances are you missed something
Jan 08, 2014 | Compaq Presario CQ62-215DX Laptop
HI, I put my compaq presario cq40-310au into hibernation mode but when I came back and the turned it on, nothing appears on the screen. The power button is on so i know there is power. The LED light on...
Welcome to FixYa!
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 12, 2011 | Compaq Computers & Internet
Blue screen after I have done system restore on compaq presario CQ60. I have tried F8 on start up to run in safe mode but nothing seems to starp the blue screen on start up now.
Welcome to FixYa
Dear user
Perform a Hard Reset first.
Disconnect devices including USB devices and media cards. Disconnect the AC power adapter, remove the battery Press and hold the power button 15 seconds . connect the power adapter -do not connect the battery- Press the Power button, Look for blinking LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Hope this helps...Thanks for Connecting FixYa...
Dec 04, 2010 | Compaq Presario Notebook
My msi wind wont start!!! i was trying to reinstall my windows using the recovery disk, so restarted my wind but mistakenly pressed f12 instead of f11 to run the boot set-up, but my screen froze (totally...
I'd like to help you, but it is very difficult to diagnose based on your description. We will need to gather more info as we try a few things.
1. Why are you reinstalling? 2. How old is the system? 3. Try the following & let me know the result: turn system back on. When the normal LED indicators are on, press & hold down the power button for 4+ seconds until everything goes off. 4. If step 3 worked, then turn power on & hit bios setup key (f2?). 5. See if HDD is detected.
Jun 07, 2010 | MSI Wind U100-030US Laptop
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
This should work....all the best
May 19, 2010 | Computers & Internet
Compaq V6305NR On pressing start button, then turns off & restart
Mostly it is due to the GMCH problem. If you can do chip level repairing, I can guide you. Please inform me if you can.
Feb 14, 2010 | HP Presario V6305NR PC Notebook
Compaq F572US won't start (led turns on, but nothing happens)
I have been having the same problem. At first I thought that the motherboard was fried and the laptop was a paper weight, but I kept it plugged in and kept pressing the power button several times over the days. It would always seem to start (screen remained off/black) and then it would just go off again in seconds. But persevarence has paid off, finally almost after a week it started up like normal and started working again as normal. I then had the same episode repeat a few weeks later, the computer was useless for a few days and again started up as I kept pressing the power button several times a day.
I believe the problem is with the standby mode. Each time the problem happened, it seems like the computer was going into standby mode and the power button was pressed again before it could competely go into standby or the button was pressed again while it was coming out of standby.
To sum it up, nothing is wrong with the cimputer components, there is some problem with the standby routine. Keep pressing the power button and hopefully you can get lucky in getting the computer to start again. Long term, I am thinking about checking whether there was a new flash update that came out that could fix this problem. I purchased the laptop compaq F72US in 2008 and never updated anything. Also worth noting that I called HP and they didn't stand behind their product.
Sep 28, 2009 | Compaq Presario F572US Notebook PC
DC5100 want start up
You need to replace the power supply, a fairly common problem.
Jul 17, 2009 | HP Compaq dc5100 PC Desktop
Dell M1530 wont turn on
A flashing ON ON Lock LED sequence is indicative of a failed Motherboard
Jul 03, 2009 | Dell XPS M1530 Notebook
Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
