Question about JVC AV-48WP30 48" Rear Projection Television
Red is all over the place but have a claer picture.
Red lines and red spots but clear picture.
  • Carl Manaloto
    Carl Manaloto May 11, 2010
    Take a picture of the problem with a cell phone camera or a digital camera and then post it on this site. I will get a better understanding of the problem.
    C-Dog
Its a convergence problem. I had the same problem you have to replace an av 110 chip in the tv.Mine was under warrenty so I had it fixed for free. Dont know what it costs otherwise.
Posted on Mar 17, 2008
Spots all over the tv panasonic pt-61lcx65
If they are large colored circles behind the picture scenes, mine had it too. Fix was as simple as service technician plugging into the EPROM and loading a software update. Picture then was better than day1.
Jan 06, 2014 | Televison & Video
Red lines are taking over
possible your tripler control is going out .This part splits the high voltage from flyback transformer into 3 high voltage leads to feed to the three picture tubes .The side for the red is likely to go out causing red picture tube to overdrive in red retrace lines..That or RED CRT BOARD is bad
Dec 06, 2007 | JVC AV-48WP74 48" Rear Projection...
Black and White Picture only. buzzing sound picture clear
Check your connection to device. If i had to guess I would say your probably using a component cable (Red/Blue/Green with Red/White audio also). Make sure these cables are in the right spot.
To test the TVs picture, bring up the TVs menu and see if it is distorted or miscolored too, if so the TV needs service.
Jun 16, 2011 | Televison & Video
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
Bubles in the claer line.
The clear line will be your fuel line.The pump would normally keep pressure on your injectors and consequently has no air. There is a non return(check) valve in the pump to keep fuel at you injectors. Sounds like this has failed. New or 2nd hand fuel pump required
Mar 20, 2009 | 2000 BMW 5 Series
Red spots and Lines on Laptop
the screen might of got wet
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 04, 2008 | Computers & Internet
Red lines and strong red tint to picture
By placing your hand over the red lens you stop it's convergence with the other two colors by stopping it's light emmission. That tells you two things, (1) convergence of the red tube is way off; (2) it hasn't yet placed any load on the 20+/- supply line or the unit would be in shutdown. You'll need to have the convergence amps replaced though. ICz103 and ICz104 are a Samsung p/n#BP13-00006A or the more common equivlent Sanyo STK394-250 and you'll need two of those. Good idea to test and replace any of the feed resistors that may have changed in value also. If any of this sounds complicated take it to a reputable shop. Most shops may have the parts on-hand and it's not too expensive a repair. With the above info you'll at least be on some higher ground with the repair shops you call to see if they have the parts and how much they generally charge for convergence repair for your model. Good Luck Bill
Jun 05, 2007 | Samsung HCL5515W 55" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Red diagonal spottted lines
These are called retrace lines they occur because of the blanking pulse not turning off the electron guns in the picture tube during the retrace period. Since this is occuring with the red gun there may be a proble with the video circuitry connected to the red electron gun of the picture tube. This would include the red amp and the red driver transistors. You will need a schematic and a multimeter to properly test these items.
Aug 03, 2006 | Sony KV-36XBR400 36" TV
JVC AV-48WP30 48" Rear Projection Television Logo
41 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
