Cpu fan is not running! shutdown (Y/N)
I got this error so I changed my fan (bought a new one) and now every time I boot the alarm still goes off! I disabled the fan detection in the bios but now it won't tell me if there is a problem in the future. Isn't there any way I could just turn off the alarm and still keep the detection option enabled ?
  • 2 more comments
  • kap0n3 Jan 12, 2008
    no 3 pin
    yeah 3 pin connector on the main board
  • totenham Feb 25, 2008
    hi all newbie first post , i have a compaq presario desktop sr1150uk .
    i recently was adding a new dvd rw drive and also decided to clean the cpu fan as it was very loud . whilst cdiconnecting the fan motor and fins i broke the plastic clip on the fan housing unit , on one of the 4 corners ,when i put unit back together it now only pwers up for about 10 seconds and then shuts down .The cpu fan does power up and run ,then shuts down after 10 seconds .
    any help would be appreciated .
    Les
  • brian c
    brian c May 11, 2010
    Did the old fan have have a 3 pin connector and you replaced it with a 2 pin?
Today i start my HP Pavilion but he did not start the error is (your cpu fan stopped after 5 mint your pc shut down) plz tell me whats the problum
i am wating for your mail
my email is sheikh_waleed@hotmail.com
Posted on Apr 03, 2009
  • 102 Answers
Or did you connect the new fan to another 3 pin connector on the mainboard?
Posted on Jan 12, 2008
MS-7297 Ver 2.1 Not booting: system fan not detected. I've bought in ebay a working msi mobo (so vendor says it works) that I can't boot because a message saying system fan not detected (bios...
you need the right heat sink for the cpu that you are using for the board check on board for cpu plug in, then plug the fan in make sure that you have enought heatsink paste on cpu not to much just enought to do the job. if that dose not do it then the board is bad.
Sep 24, 2013 | MSI Computers & Internet
Ibm thinkcentre cpu fan runs on high after shutdown
Open the Control Panel. Power Options, Change/Adjust power off settings, change Sleep and Hibernate to Never, set to High Performance. A reboot everyday will reset your computer.
Jan 18, 2013 | Computers & Internet
Tecra-A2 goes into critical shutdown.What can I do?
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Dec 26, 2012 | Toshiba Computers & Internet
No boot and CPU overheat warning siren. The CPU fan appears to be working. This old computer was recently packed up and moved, but booted once after the move.
Although the cpu fan may be working, the alarms are set to a temperature setting, so if the heat-sink that the fan is mounted gets clogged with dust ,dirt hair etc.. the processor temp rises and the alarm goes off. And in some cases if the user doesn't shut it down within a certain time period it is shut down automatically.
When you boot it up, the temp might be rising to that setting faster than the operting system can load.
Try a vac to clean it / or compressed air to blow it out
Sep 15, 2010 | Intel D945GNT Motherboard
Fan Error on IBM T41
This is normally the CPU fan - is it working?
Is it connected to CPU fan socket on mainboard or a different socket - it must be connected to correct socket or fan will not be detected?
Aug 09, 2008 | Computers & Internet
Booting problem
just check with new powersupply
Jun 11, 2008 | ASUS P5GD2 Deluxe Motherboard
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Computers & Internet Logo
1,377 people viewed this question
David Payne
David Payne
