I have a Maytag electric dryer model, #MDE7600 bought in 2000. It no longer heats up but the sensor still blinks when it's on the mostly damp part of the cycles. Is it worth fixing? Do fuses need to be replaced and if so, where are they located and is it possible for me to repair it?
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER not heating
Check the terminal block and make sure you're getting 220. If you only get 110, the dryer will run but without heat.
SOURCE: my maytag dryer is blowing cool air
it should be located it a small trap door around the drum either on the side , inside , or on the bottom. to replace it you must remove the screws the hold it in place slide it out remove the wiring and then slide the new one in screw it back in and plug the wires back on it. please make sure during this process the dryer is unpluged from the wall plug. hope it works out for you .
SOURCE: Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
SOURCE: need to replace drum belt on Maytag electric
Hello.
Go to this link and type in your model number. This will get you the tech sheet for that unit and will show you the diagram.
http://www.servicematters.com/maytag_library/html/index.html
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
