Question about Electrolux Z5935 Bagged Canister Vacuum
Electrolux Oxygen 3
I cannot get the power cord to catch and lock after I pull it out to plug it in. My old Electrolux would simply lock the cord each time I pulled it out. This model doesn't seem to have a decent catch mechanism and recoils completely every time I pull it out. I have two machines and I have the same problem on both.
  • elvemel Jan 18, 2008
    Interesting solution, but both vacuums are brand new and haven't seen much dust yet. In fact, we are still on the first vacuum bag in one of the units!
    President:
  • 1,673 Answers
Most cord reels have a stop on it, it is a rubber wheel and when dust gets on the wheel, they won't always stop the reel. It would have to be opend up to get to the cord reel, then you could clean it out.
Posted on Jan 17, 2008
  • Lauren Junge
    Lauren Junge Jan 18, 2008
    Didn't know they were that new, then they are in warranty and you should take them to a warranty shop along with proof of purchase.
Electrolux Epic 6500 SR - power/cord light not lit, doesn't start & blows house circuit breaker
If your vacuum has had 20 years of service it may be simply too old to repair.
Apr 15, 2017 | Electrolux Vacuums
How to get to wiring plug
If you're talking about the cord that you pull out from the reel located at the rear of the machine, you'll have to take the top cover off first. Usually two philips head screws located under rear exhaust cover and one maybe two near the front end. Once that is removed, there will be two more philips screws, one on each side of the top rear of the machine and one on the bottom. Remove all three of them, pull about a foot of cord off of the reel and get it to catch, the using the heel of your right hand, hit the very back of the machine, (the rubber bumper part) on the top with a motion pulling toward the back. This may take a couple of tries if you're not used to removing this part, but one or two swipes should eventually loosen the rear cover. Once it is loosened you may carefully pull it out of the back end of the machine and take off the two wire connections. This will free up the cordwinder assy. so you can take it to a spot where you have some room to work. Now lay the assembly on it's back and take the four screws, one from each corner of the rear cover, out and lay them aside. Thread the cord plug through the opening and wind the free cord back onto the reel, allowing the spring to pull it slowly out of your hand and then wrap the plug end around and around the reel till the spring is unwound, then you can remove the "C" clip from the center post, sometimes hidden under a cardboard washer. With the clip removed you can gently pull the cord reel up and off the post, carefully bringing the rewind spring up and off it's post as well. If you've tested the cord and are sure that it's your problem then you can cut the remainder of the cord from the reel and throw it away. The reel is easier to deal with without the cord on it. Turn the reel over so the back cover is exposed, there should be three screws that can be removed so you can take the connections loose from the posts inside and make ready for the new cord. Once you've attached the new cord and tied your strain relief knot, like the one you removed, you're ready to wrap the cord onto the reel and just reverse the procedure. When you get ready to put the loaded reel back into the cordwinder body, just before you put the cover on, wrap the plug end around the reel three times. This loads the spring so that it will pull the cord completely back into the unit. And it doesn't hurt to drop a spot of oil onto the top of the post for the spring.
Nov 11, 2013 | Electrolux C101 Bagged Canister Vacuum
The power chord on the 2100 electrolux will not retract
Try standing the vacuum on end, or at a near vertical position, and gently tugging on the cord a few times. This will usually cause it to retract. The problem is usually caused by pulling the cord out too far. Avoid doing this as it can result in disconnecting or breaking terminals and/or wiring.
Jan 12, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
http://www.aerushome.com/storelocator/
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
I have an epic 6500SR I'm trying to change the
You really don't want to get into the vacuum. You could cause more damage than what you have now. After you do get into the vac, the cordwinder is another monster to get into.
There are two strips,one on each side of the cleaner under the rubber bumpers. The strips have to be removed by pulling off the bumper and pull them out the front of the vac.This is not easy. After you get the locking strips out, turn the vac over and pull the bottom off. Then you can see the cordwinder.
The best thing to do is take the vac to a Aerus/Electrolux shop for repair.
Nov 02, 2009 | Electrolux Lux 5500 Canister Vacuum
The cord on my electrolux Epic 6500 has been pulled too far out and will not rewind. How can I access the cord reel to rewind?
There are two keys holding the body together, underneath the bumpers on the side of the vac. With the bag door open these keys when gripped with pliers will slide forward to release the body panels.
Before opening the vac, gently push the cord back inside the housing.
2 possibilities:
If the spool rotates and allows the cord to push in , the body must be disassembled, and the cord winder removed and the spring reloaded. This is tricky work. you will need to wind the entire cord onto the spool, then load 3.5 rotations onto the coil spring for tensioning, then reassemble. It's a bit like working on a land mine of you're new at it. Wear safety glasses.
BUT if the spool is locked from the outside and the cord wont push in or pull out, a fine , long blade screwdriver can be inserted diagonal to the body through the cord slot and with luck you can lift a cog of the spool releasing tension and the rewind will work. try that first , but be gentle . You must release the cord spool allowing a a dog ear catch cog to release inside by gently lifting upwards.
Post back to say how you made out,
Or look for an AERUS Electrolux service shop.
Sep 27, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Oxygen 3 model 7020A contols not working
You need to replace the hose itself. The buttons in the handle a very cheap and go bad all the time.
Aug 17, 2009 | Vacuums
I havea -1year old Oxygen Vacuum and the powerhead just quit.
the vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
Jun 26, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Z5935 Bagged Canister Vacuum Logo
157 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
