Question about Metra Antennaworks 44-PW64
How to wire antenna for 1998 nissan maxima
Can you help me need to install antenna for 1998 nissan maxima and can't get power to it
  • sandman12 Dec 30, 2008
    Antenna on my Nissan Maxima 98 is stuck. Please help me with how to reinstall the new antenna.
  • 383 Answers
Kevinrose: are you installing a factory antenna or an aftermarket?
The factory antenna will get a constant power supply which is a pink or purple wire. This wire is hot whether the key is on or off.
The way the antenna is made to go up, is through a second power source which is black/red wire. When you turn the radio on, this wire goes hot when the ignition is switched in the accessory or on positions. When you turn the radio off or turn the ignition switch completely off, the antenna will completely retract. The circuit for the antenna is served with a 10 amp fuse which is located on the driver's side to the left of the steering column, The fuses should be labeled on the door you remove to access the panel.
CAUTION!!!! most aftermarket antennas DO NOT have the kind of connector that will all you to plug or easily connect the factory antenna cable to it. You wil have to make an adaptor.
So before taking things out of the packaging check this out or you will find your self with an antenna to sell.
sandman: Depending on the situation you are describing is the solution This is contingent on your having removed the old antenna and it's remains. Ideally you and one other person to assist would be best for this job. Have the radio turned on and feed the antenna mast cable in with the teeth facing the rear of the car. Push the cable down until it stops. At that point be prepared to feed the cable in as the motor draws it downward and be prepared to feed the mast it self into the antenna housing where it will continue to rectract until it stops nearly flush with the fender . At the time it stops, you will hear it going bump, bump, bump a number of times. This is normal. Once retracted, you can reinstall the retaining nut or collar which prevents the antenna from being pushed out of the housing. The collar has two small holes in the top which are for a special tool. A pair of snap ring pliers will work in their place.
If you have the remains of the antenna cable inside of the antenna assembly, unless you are somewhat skilled, it may be better to remove the antenna assembly and bring it to a shop for the to replace the mast.
If I can be of further assistance....let me know.
Posted on Apr 18, 2009
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
How can i replace 1991 maxima radio system?
The original radio is a BOSE system and it has a buit in amp. So if you replaced the deck you need to replace the speakers all so. Don't cut the wires to hook-up the deck buy an addapter KIT. It's not just the stereo that runs though that harness the factory alarm does all so and that will cause you problems. Anyway back to the stereo you need to add an amplifier and problem sovled.
Jul 23, 2012 | 1991 Nissan Maxima
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
How do I remove stereo from dash?
Check this link for Nissan Maxima Remove Radio guide.
I really hope this help (rememmber comment and rated this help). Good luck.
May 11, 2010 | 1996 Nissan Maxima
I have a 1997 nissan maxima and i cant get the radio working help
make sure your antenna is hocked in good, its the ground
Sep 24, 2009 | 1997 Nissan Maxima
Had new antenna installed now clock won't come on and automatic
Take it back Whoever fitted antenna has left wires unplugged
Jul 09, 2009 | 1997 Nissan Maxima
1998 maxima gle Tune-up needed what parts do i need
Every 30,000 miles you need an air filter, every 60,000 a fuel filter, every 100,000 spark plugs. That's it.
Oct 11, 2008 | 1998 Nissan Maxima
1999 Nissan Maxima Keyless remote, power antenna, & clock problem
Thanks that solution about fuse #40 helped solve my same issue! Thank youuuuu
May 23, 2008 | Apple iPhone Smartphone
Car Audio & Video Logo
1,674 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
