Question about Maytag Neptune MDG5500AW Gas Dryer
My maytag dryer does not get hot how can i fix it the model number is dg212 series 01
  • stanfam Jan 01, 2009
    Model DG 212 Series 05 tumbles but no heat. I see no fire at the front.I'd like to fix it myself but have no idea if it's costworthy with it being gas & have to have someone come to disconnect the gas lines.Or do i have to disconnect the gas line to it? Any help would be appreciated
We bought this machine last year, converted it to propane & have loved it. All of a sudden there is no ignition ( fire). I have taken off the front & cleaned everthing I could see. Still no fire. I have check the gas supply, the drum is spinning, the only thing I think I heard last year right after it started and right before the "FIRE" was a clicking sound? What ever you might sugest would be greatly appriecated! Thank You, Don Wagner Jr @ SmoothSeal1@aol.com
Posted on Jan 17, 2008
Maytag Bravos Dryer quiet series f01 code
F-01 Means the main electronic control board is likely to have failed.
Unplug the dryer for 5 minutes and the plug the dryer back in. If the code reappears, replace the main electronic control board.
This is where I would start.
Maytag Dryer Circuit Board Timer Parts
Dec 19, 2017 | Maytag Dryers
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
The timer on my Maytag DG212 dryer sticks and does not advance so it just keeps running.
You will need to change out your timer, as it is non-repairable.
Hint:...Be sure to get the same brand/mfg of timer, or be somewhat of an electrician because if you do not get the same timer it will not be wired the same.
Also only remove and replace one wire at a time, it will keep you out of trouble and ease the installation of the timer.
Please rate me
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Re Maytag dryer model DE410, serial number 285802, series 01. How much of machine needs to be taken apart to tighten blower fan on end of motor shaft. Thanks. Murray bally.duff@sympatico.ca
Sorry to read about your problem, I hope this helps you out.
all most all of it
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Maytag Dryers
My Maytag DG212 gas dryer is not drying well, the hose and vent are clear. What I see is the flame will only last 10 to 15 sec. and then go out.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 02, 2010 | Dryers
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Maytag Dryer has lost heat...
I would think the timer is not used but a humidifier when on auto dry mode. Check the humidistat, should be either make or break contacts, open or closed.
Nov 11, 2017 | Maytag Dryers
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
if burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Sep 16, 2008 | Maytag Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
184 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
