Samsung P1253 washing machine doesn't spin fast leaving clothes wet
Have a samsung p1253 machine, its 13 months old so just out of warranty. Had to have the water pump replaced after 1 months so should have known we were going to have problems. Anyway i noticed the countdown was suddenly giving random digits it was on 0 then 49,58,38, etc so i turned it off and then back on a few mins later, It was going through the cycle fine this time until it got to 9 mins remaining on spin. It started spinning slowly clockwise then anti clockwise but would not spin fast it took about 30 mins for it to countdown to the end but the washing was still soaked. I then removed all the washing from the machine ( a few bed sheets ) then tried a spin cycle and it was fine but as soon i as put one sheet back in the machine would go to spin fast, then i could hear a slight knocking and the machine would just repeat the slow spin and take ages to finish agian leaving the sheets soaked. We have noticed lately that the machine was getting more vibrations when spinning fast and had to constantly level it off but then it would un level itself after a few weeks. I have read that it has 'Fuzzy logic' and if it detects excess vibration etc it will try 7 attempts to nomalize, could something have come loose therefore increasing the vibration resulting in the 'fuzzy logic' thing to come in to effect?
Any help appreciated as with 2 young girls you really need a washing machine to work properly. Many thanks
  • 4 more comments
  • Anonymous Jul 28, 2008
    Samsung P1253 washing machine doesn't spin fast leaving clothes wet problem, and notify you when a new solution is offered.
  • Anonymous Aug 19, 2008
    I have the same problems, have done the same things to fix it but the thing still isn't working. Had a washing machine man in to see if he could fix it and he told me it was the computer and i am going to have to get in touch with samsung themselves. Gonna cost me more money.
    I also had to change the pump it went 2 days out of warranty
  • Anonymous Sep 16, 2008
    clothes come out wet. the spin cycle does not operate properly. Instead of spinning correctly the machine acts like it is spinning and agitating and agitating at the same time.
  • Anonymous Sep 18, 2008
    similar problem luckily JUST within guarantee, comet engineer came out and installed new drain pump and it worked fine.... for 3 months. Now it's displaying error code 6e which isnt listed anywhere. I will never buy another samsung washing machine.
  • stig118 Mar 09, 2009
  • Christian Huebner
    Christian Huebner Aug 23, 2014
    I had the same problem, it turn out the be a faulty control board.
I found a solution on another site. At first I didn't think it would work, but it did....
The samsung washer is very sensitve to balance. Although you may feel you have all of the feet tight to the the spin cycle, as it runs up to the middle speed, watch each foot closely, one of the feet will lift up and down just a tiny bit (or more)
Lift that corner slightly and Tighten that foot. Continue to run the spin and watch the feet, make sure none of them move at all.
Mine immediatly went up to the faster speed and wrang out the clothes like it did the first day i got the machine. Once done, be sure to LOCK the feet with the ring at the top.
good luck!
Posted on Dec 18, 2010
5 Suggested Answers
SOURCE: samsung p1253
LE means locked rotor or overload in motor. Check for binding or mechanical resistance. check motor winding resistance. Also check 3 pin connector in motor harness, harness between stator and main board or Hall Sensor on motor could be defective
Posted on Dec 28, 2007
  • 57 Answers
SOURCE: samsung p1253 hole in outter
Hi I take it that the outer drum is made from plastic the only thing that would cause this problem is a large coin got into the drum and as the machine was spining the force made it hit the outer drum and chip it making a hole
Posted on Jul 18, 2008
  • 49 Answers
SOURCE: drainage wont work on samsung p1253 washing
could need a new pump. could be something jammed in pump
Posted on Nov 28, 2009
  • 15935 Answers
SOURCE: Letters UE on display
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
My washing machine is spinning but the clothes are still dripping wet. I have put it on a separate spin cycle too.
If the washing machine is not draining, there might be a small coin stuck in the impeller pump.
It's probably best to get a repairer to do the job, otherwise yuo might invalidate the warranty.
Jan 30, 2015 | Washing Machines
Samsung WA82BSL cloths still wet
Have you observed the machine in spin cycle-if it is not draining or spinning that would leave the clothes wet-cheers Denny
Oct 24, 2013 | Samsung Washing Machines
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
Samsung J845 washing machine will not spin.
could be the dampers have failed or the drum mount is broken, try a spin with no clothes, if it is spinning with noise or the drum is not running true it will need major repairs.
Apr 19, 2010 | Washing Machines
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
3,498 people viewed this question
Top Washing Machines Experts
